You were right Soundguy. I found where the two wires were connected together and it was a good tight plug (nothing wrong). So I started the process of elimination, beginning at the battery, trying to crank it after each connection I checked. When I got to the starter side of the solenoid, it seemed tight, but with some force I did make it move. When I turned the key to crank, sparks shot out from the connection. I got my tools and took the cable off and cleaned everything up good and put it back on good and tight and it fired up, first try. I killed it and tried it several more times, each time cranking it. I'm satisfied now that it was just a bad connection on the solenoid. Again I want to say a big THANK YOU to all who had a part and/or suggestion to my problem. I really appreciate and hope I can somehow return the favor in the future.
"If you've got a car, you've got a ride. If you've got a truck, you've got a better ride. If you've got a tractor, you've got it all."
