I'm having a problem with the safety switch on my `72 Ford 2000. Yesterday I assumed the switch was stuck because when I finally put the hi/low selector shift in neutral position the tractor cranked up. Today, I found that neutral position is not working either. I had to move the shifter to numerous positions before the starter would finally engage. Is there a way to by pass this safety switch without going into the transmission? It took me about 5 minutes to find a position so the tractor would start. I just want to do away with the safety switch function if I can. Any suggestions?
"If you've got a car, you've got a ride. If you've got a truck, you've got a better ride. If you've got a tractor, you've got it all."
