Results 1 to 3 of 3
08-05-2011, 04:18 PM #1New Member
- Join Date
- Aug 2011
- Posts
- 2
- Tractor
- John Deere L111 2005
2005 Briggs and Stratton intek 20hp
Hi,
Very frustrated with my deere L111. Just spent over 200 dollars trying to fix this engine. It started at about 100 operating hours and now at 162. Bought this Deere used with only 40 hours and worked great up to about 100 hours. I was mowing for about an hour when it choked sputtered and quit. Restarted it and had to use choke full on to nurse it back to the house. First repair found dirt and garbage in fuel lines and in the filter. Cleaned it out but still having problems. Next repair was to use B12 in fuel and change fuel pump. Worked for about 30 minutes and same problem. Next repairman came and again cleaned lines, new filter and pump again..... good grief !!! Yesterday I ran it for about an hour. Not an easy task as I had to restart over and over, use different running speeds (throttle) and combination of chokes. This morning it wont ever start. Thought about the gas cap being clogged so I have also tried to run the tractor with cap slightly
open so the tank does not build up a vacuum in it. That isn't it either. HELP
PLEASE !!!!
Norm
08-05-2011 04:18 PM # ADS
08-05-2011, 04:24 PM #2Gold Member
- Join Date
- Mar 2006
- Posts
- 485
- Location
- BEECHER CITY, IL
- Tractor
- KIOTI DK45S
Re: 2005 Briggs and Stratton intek 20hp
Possible intermittent problem with the afterfire solenoid
ILLINOIS ENGINE, Beecher City, IL
Briggs and Stratton MST (Master Service Technician)
ILENGINE over at Lawnmowerforum
08-05-2011, 04:30 PM #3New Member
- Join Date
- Aug 2011
- Posts
- 2
- Tractor
Man, you must be sitting at your computer same as me. When you mention that do you mean the fuel cutoff up front by the exhaust ports? Because I have had that question lingering in the back of my head since the problem seems to happen normally when operating temp is high.
Norm
Similar Threads
Briggs & Stratton Leaking Oil
By Localmotion in forum General Lawn & GardenReplies: 8Last Post: 04-25-2012, 07:53 PM -
Help with date of mfg on Briggs and Stratton 18 hp engine.
By chad22 in forum General Lawn & GardenReplies: 2Last Post: 05-08-2011, 08:03 AM -
briggs and stratton 14hp armature question
By tpolley in forum Parts/RepairsReplies: 1Last Post: 01-31-2011, 12:36 PM -
Briggs & Stratton Fresh Start Fuel Stabilizer?
By Doc_Bob in forum Oil, Fuel & LubricantsReplies: 11Last Post: 07-29-2009, 10:32 PM -
Kohler vs Briggs & Stratton
By stuart in forum Buying/Pricing/ComparisonsReplies: 24Last Post: 03-08-2004, 12:53 PM
