Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    10
    deere 2020
    Default deere 2020 fuel in oil
    I have 4 cyl deere 2020 recently purchased. when i got it, after sitting for about 6 years, I changed the oil and when draining about 4 gallons came out of oil drain, with a strong smell of diesel fuel. changed the oil and put new oil in (7 Qts) after about maybe 10 hours of operation it is about 1/2-3/4 quart high and again smells of diesel fuel. I cannot find anything on adjusting fuel pump for a rich running machine, or is my problem more serious where i need to redo some cylinders??
  2. #2
    Gold Member
    Join Date
    Mar 2005
    Posts
    394
    The Real Central PA
    BX25D, JD 820
    Default Re: deere 2020 fuel in oil
    I had a similar problem with my JD 820 several years ago. If I recall correctly, there was a diaphragm in the fuel pump that ruptured, allowing fuel to enter the engine block. I replaced the fuel pump and the problem was solved.
    If ignorance is bliss, then why aren't more people happy?
  3. #3
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,257
    manitoba
    Many
    Lift pump !
  4. #4
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    could be the front seal in the injection pump
  5. #5
    New Member
    Join Date
    Aug 2011
    Posts
    10
    deere 2020
    thanks for all the advice, i will investigate both potential solutions, thanks again Roy
  6. #6
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,457
    Ararat Vic Aus
    G'day most common cause of fuel in oil have both been mentioned
    1. Lift pump ( or prime pump as you lot call it)
    2. Front seal on the injector pump
    Hope it is No 1 for you as this is alot cheaper and easier than 2. Good luck and let us know how you get on
    Jon
  7. #7
    New Member
    Join Date
    Aug 2011
    Posts
    10
    deere 2020
    Thanks Jon, will do
  8. #8
    Member
    Join Date
    Nov 2004
    Posts
    43
    Indiana
    1966 Cub Cadet 124
    Quote Originally Posted by banjodunn View Post
    Jon
    I had a Cummins engine that did the same thing, only it was a bad (internal)leaking injector.
  9. #9
    New Member
    Join Date
    Aug 2011
    Posts
    10
    deere 2020
    Replaced gasket and fuel lift but did not fix the problem, another forum a guy talked about replacing a diaphragm in the fuel pump?? This sound logical to anyone?
  10. #10
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,238
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Depending on type inj pump umbrella seals(parts key #21) on inj pump drive shaft need replacing. While inj pump is off check bronze bush(parts key #20) in inj pump for wear.
    Attached Thumbnails Attached Thumbnails deere 2020 fuel in oil-t17093_________un01jan94-gif
Similar Threads
  1. Oil & Fuel Motor Oil as the Hydraulic Oil in Power Trac
    By DieselPower in forum Power Trac
    Last Post: 12-11-2014, 07:45 PM
  2. Natural Gas Generator
    By Rat Rod Mac in forum Rural Living
    Last Post: 04-16-2013, 07:42 PM
  3. Hey Rox, what can you tell me about olive oil?
    By N80 in forum Rural Living
    Last Post: 09-03-2008, 05:10 AM
  4. 2007 Chef of the Year Southest & Olive Oil
    By rox in forum Family and Friends (Announcements & Notices)
    Last Post: 07-30-2007, 02:21 PM
  5. Motor oil and other fuel additives
    By nosliw in forum Oil, Fuel & Lubricants
    Last Post: 02-17-2007, 12:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
