Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    2
    Ford 555 backhoe
    Default 1978 Ford 555 backhoe fuel transfer pump problem
    I encountered a problem this summer as I was working the old Ford on moving some dirt in our hay meadow. I would stall it out, and couldn't get it to start again. I bled the injectors, hooked it up to a shop battery charger (225 amp) and got it to go doing this, but after reading the shop manual decided that the fuel transfer pump might be the problem. The manual said that, in hot weather, a worn out fuel tranfer pump might cause hard starting and loss of power due to the lower viscosity of the warm diesel fuel. The next time it quit (I stalled it out) I got a hose and sprayed down the tranfer pump section of the fuel injection pump with cool water. That did the the trick. The engine started right up. I have successfully restarted the backhoe 5 more times using this method, so my guess is that the tranfer pump needs to be replaced. Can anyone out there confirm that I have correctly diagnosed the problem?
    Has anyone out there replaced a tranfer pump on the fuel injection pump on a Ford 555? If so, can the job be done by a home mechanic with no special calibrating equipment? Does this type of repair require recalibration of the fuel pump? Does anyone know where I can get step by step for performing this repair? Does anyone know where I can order the transfer pump (not a whole new fuel injection pump)?
    Thanks!
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,266
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Default Re: 1978 Ford 555 backhoe fuel transfer pump problem
    555? that's a CAV rotary style injector pump? If so, R&R of the transfer pump is generally not thought of as a DIY project. Best bet is to either get the injection pump overhauled by a professional diesel shop, or buy one of the imported CAV knockoff injection pumps available online. Removal and installation of the pump IS a DIY project for many owners.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
  3. #3
    Member
    Join Date
    Jan 2008
    Posts
    39
    Luther Willis Hill, AR
    Pettibone, Ford, Massey Ferguson, International, JD, David Bradley, home mades
    maybe check how hot the engine is getting, clean and flush the radiator, check the fan and belt, thermostat, an injection job will easily cost over a thousand. Plus, you have to be particular how you take it off and put it on, and time the pump.
  4. #4
    Gold Member joecdeere's Avatar
    Join Date
    Apr 2002
    Posts
    472
    Cumming,Georgia
    Jim, this is by far NOT a home repair job!
  5. #5
    Join Date
    Aug 2009
    Posts
    180
    loganville ga
    wheel horse c-100
    from past experience what your describing is the injection pump itself the putting of water on the injection pump is an old trick to help figure out what part of the injection system is not working properly and as you stated when it got wet and cooled off all was well until it got hot again this jobs requires special tools and books to reset the pump when you rebuild if you cant find an pump builder in your let me know i will put you in touch with one close to you.
Similar Threads
  1. Oil & Fuel Kubota Fuel Problem
    By ih574 in forum Kubota Owning/Operating
    Last Post: 11-12-2012, 02:58 PM
  2. Maybe we should have gotten a crankcase heater in the L3940!
    By Grateful11 in forum Kubota Owning/Operating
    Last Post: 12-21-2010, 08:23 PM
  3. Bad fuel aftermath
    By farmgirlky in forum Kubota Owning/Operating
    Last Post: 08-23-2010, 08:40 PM
  4. Motor oil and other fuel additives
    By nosliw in forum Oil, Fuel & Lubricants
    Last Post: 02-17-2007, 12:12 AM
  5. Oil & Fuel TY290 engine / 2i70 fuel injection pump
    By kingjames8283 in forum Chinese Tractors
    Last Post: 01-25-2007, 09:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
