Problem solved. 15 Amp fuse blown.This model L3710 Kubota has a fused circuit for the fuel shut off. When the switch is turned to the off position, a timer modual is activated sending power to the fuel shut off relay/solinoid for 5-10 seconds, cutting off the fuel and shutting down the engine .When the timer times out power is removed and the fuel shut off is returned to the on or open position by a spring in the relay/solinoid.I had been using the manual pull lever under the switch till I could trace down the problem.If you must use the manual pull lever to shut down, rember to push it back in or you will not be able to start back up the next time , it's easy to forget. I hope this will help someone else with this problem.Thanks everone for your help.
