NormL
- Joined
- May 9, 2011
- Messages
- 662
- Location
- Manitoba, Canada
- Tractor
- Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
Is that bearing the one you are running? If so, what keeps the grease in it?
There is a seal hiding from sight. In the first photo, if you look closely, you'll see that the bearing's inner race extends about 3/8ths". The seal rests there. I popped the bearing off after taking the pic and put the seal in place and then assembled everything the way you see it in the second photo. I did it that way because I was using the bearing itself to protect the spindle from welding spatter which I would have had to remove otherwise.
