Results 1 to 4 of 4
  1. #1
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    Default John Deere 2040 hydraulic leak
    Monday in shop class i get to take the school's 2040 apart to replace a leaking hydraulic hose. To me I see it as an opportunity to learn a little about how the 2040 work's and get the hydraulic fluid off the shop floor as it is a hazard and liability on the school waiting for someone to slip and fall on the slick concrete. The problem hose is the siphon hose but to get to it requires removing the front weight, the hood, and many other things. Supposedly it is a 4 hour job, I guess we will see how long it takes. I attached a few pictures of the problem area and teh serial number, not sure if that will help me looking for a parts diagram or not, I will find out soon. Any procedure ideas to make it go a little faster/easier are welcome as well as any advice. Thanks guys!
    Attached Thumbnails Attached Thumbnails John Deere 2040 hydraulic leak-forumrunner_20110930_185305-png   John Deere 2040 hydraulic leak-forumrunner_20110930_185335-png   John Deere 2040 hydraulic leak-forumrunner_20110930_185411-png
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, Bobcat landplane ,4 in 1 bucket, Pallet forks
    2005 John Deere L118
    42" deck, bagger
  2. #2
    Advertiser
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    Default Re: John Deere 2040 hydraulic leak
    Here is the diagram of the area I will be working around. I think that hose 18 is leaking but would you start at the pump? This is just the breather hose that leaks, It siphons hydraulic fluid from the pump once the tractor is shut off and leaks especially bad when it is parked warm. Any suggestions on if it is the hose or is it the pump itself? I have taken the hydraulic pump off my Yanmar before but didnt go any further into it. Could it be the hose or something else?
    Attached Thumbnails Attached Thumbnails John Deere 2040 hydraulic leak-rwp4487________un01jan94-gif
    My Fleet:
    42" deck, bagger
  3. #3
    Advertiser
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    Got it fixed today. There is a piece of sheet metal under the frame between the hydraulic pump and the front axle. Pulled two bolts, pulled off the old hose, put in the new one, hooked it all up and the leak is no more. However, the lift cylinders on both sides leak and need rebuilt and the air filter is "black" with hydraulic fluid, grease, and gunk. It was really in sad shape, at least we got it fixed. Spent 2 class periods on it, got it somewhat cleaned out, the radiator was very bad, got it cleaned up.
    My Fleet:
    42" deck, bagger
  4. #4
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,445
    Ararat Vic Aus
    G'day sorry i did not see this a little earlier as this bleed hose is a common failure on those models i would suggest to you and your instructor that you replace all of those bleed hoses i think from memory there is one that goes back to the right side of the trans too. Well done though it sound like you have a little bit of work ahead of you yet
    Jon
Similar Threads
  1. John Deere 2305 Compact Tractor Transmission and rear PTO failure
    By JBarnes6767 in forum John Deere Owning/Operating
    Last Post: 04-18-2017, 01:44 AM
  2. John Deere 318 Rear End Leak
    By rwc318 in forum John Deere Lawn & Garden
    Last Post: 04-23-2015, 03:25 AM
  3. CL Scam?????
    By Kubota 2350 in forum John Deere Owning/Operating
    Last Post: 11-02-2010, 07:55 PM
  4. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 05:03 PM
  5. Home Depot
    By BrokerBob in forum John Deere Buying/Pricing
    Last Post: 07-12-2002, 10:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
