Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Default Re: 2 Cycle Carburetor Cleaner
    Another vote for seaforam
    If that fails, a teardown is in order. Watch the carb cleaners on any rubber on the carb (gaskets etc) , some cleaners really do a number on it.
  2. #12
    Gold Member jones6780's Avatar
    Join Date
    Nov 2008
    Posts
    341
    Lizella, Ga.
    Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
    I got this link from one of the forums. Its a list of stations that sell ethanol free fuel, listed by state. Quite a few in Texas.
    Ethanol-free gas stations in the U.S. and Canada
    Russell
  3. #13
    Elite Member ToadHill's Avatar
    Join Date
    Oct 2005
    Posts
    2,711
    Catt county New York
    Kioti DK35, Ford 8N, Oliver Cletrac
    You can buy "Real" gas at most marina's. I get all my small engine fuel at the local marina.
    I can't control my day but I can control my attitude.
  4. #14
    Join Date
    Mar 2008
    Posts
    116
    Collins, NY
    John Deere 855
    Quote Originally Posted by Fixemall View Post
    Seafoam will work but, spraying it in will not expose it to the clogged jets, you must introduce it into the carb via the fuel line.
    Fixemall is absolutely correct. You are unlikely to fix any gummed carburetor by simply spraying stuff in it while it is running. I always thought it was false advertising of sorts when you read these cans that tell you that you can fix a gummed carb by spraying their product in a running engine.
    -Jay
  5. #15
    New Member
    Join Date
    Sep 2011
    Posts
    18
    John Deere 4510
    Quote Originally Posted by ak9 View Post
    Bird
    I've had sooo many issues with small engine carbs whether 2 stroke or four in the last 2-3 years.. unreal ! I replaced quite a few carbs ( Jacks smallengines.com) because of the "reformulated gas"(10% alcohol). The new alcohol mix seems to really mess with small engines.This is not my opinion ...proven fact. Unfortunatly for me is all that is available locally.
    I also only run 93 octane & w/ Stihl HP Ultra synthetic in my 2 strokes.
    I've added lead additive to my mix and it does seem to help along with stabil.
    I also never leave any gas in the carb/ tank for any lenght of time after use
    ak9
    Try StarTron instead of Stabil.
  6. #16
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,572
    Texas
    Unfortunately, the replies to this thread confirm what I suspected. Oh well, it's running great right now without doing anything. So I appreciate all the replies.
    Bird
  7. #17
    Veteran Member 6sunset6's Avatar
    Join Date
    May 2007
    Posts
    1,028
    SE NY
    NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's, MF 30 TLB
    Quote Originally Posted by Bird View Post
    I've no experience at all with Seafoam. In fact, on TBN is the only place I've even heard of it. I do use Stihl HP Ultra synthetic 2 cycle oil and add Stabil to the gas.
    I may be wrong but I think I read that Stihl Ultra has stabilizer in in already.
    Saves a step in the memory process.
    Bob H
    NH 2007 TC34DA 1985 MF30E Hoe
  8. #18
    Join Date
    Mar 2000
    Posts
    40,572
    Texas
    Quote Originally Posted by 6sunset6 View Post
    Oh, it does say right on the bottle "contains fuel stabilizers", but I add some Stabil anyway.
    Bird
  9. #19
    Join Date
    Mar 2000
    Posts
    40,572
    Texas
    Anyway, it ran great today and dethatching the back yard wore me plumb out. I'd really just gotten started good when I made the first 2 photos and then had some help filling 8 contractor bags later.
    Attached Thumbnails Attached Thumbnails 2 Cycle Carburetor Cleaner-dscn0348-1080-x-810-jpg   2 Cycle Carburetor Cleaner-dscn0349-1080-x-810-jpg   2 Cycle Carburetor Cleaner-dscn0351-1080-x-810-jpg   2 Cycle Carburetor Cleaner-dscn0352-1080-x-810-jpg
    Bird
  10. #20
    New Member
    Join Date
    May 2011
    Posts
    16
    Pacific Northwest
    John Deere 5075M, Bobcat Toolcat 5600
    The ethanol content in the new fuel formulations just ruins the fuel pumps and metering diaphragms in 2 cycle carburetors. Using a carburetor cleaner on a running machine would harm these components as well as the neoprene type tips on the metering and mixture needles.
    Using the 89-92 octane gasoline and the best oil mix with stabilizing additives you can afford, is highly recommended. Run the tank and carb dry when you aren't going to use it for a few weeks or longer will also help tremendously.
    We are rebuilding small engine carburetors constantly. About every two years it seems for most machines. Most kits are about $12. If you're mechanically inclined, it's pretty straightforward. Your local shop guy should be able to do it in 1/2 hour.
    Also, your screws being 'all the way open', do they have limiter caps on them? Most limit what the consumer can do to the adjustment (because of the EPA standards).
Similar Threads
  1. Ford 800 hard steering to left
    By george46 in forum Parts/Repairs
    Last Post: 05-31-2017, 12:15 PM
  2. New Driveway- 2 pavement options..help!!
    By JBS71383 in forum Projects
    Last Post: 09-22-2013, 07:51 AM
  3. 2 Cycle Oil mixed with gas
    By SGStriglos in forum Oil, Fuel & Lubricants
    Last Post: 09-04-2010, 01:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
