Results 1 to 10 of 13
11-26-2011, 04:25 AM #1New Member
- Join Date
- Feb 2007
- Posts
- 4
- Location
- S. E. Alaska
- Tractor
- '79 406 Unimog (does that count?)
1 3/4" 6 spline PTO shaft
Where can I find one this diameter? It's for the front PTO on my Mog and goes to an S3 Schmidt snowblower.
All I can find is the 1 3/8" diameter.
Thanks,
Dave
11-26-2011 04:25 AM # ADS
11-26-2011, 07:18 AM #2Veteran Member
- Join Date
- Jul 2003
- Posts
- 1,301
- Location
- SW Indiana
- Tractor
- Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Re: 1 3/4" 6 spline PTO shaft
Did you try searching the metric equivalent?
11-26-2011, 02:33 PM #3
11-26-2011, 02:57 PM #4Veteran Member
- Join Date
- Jul 2003
- Posts
- 1,301
- Location
- SW Indiana
- Tractor
If it were a common spline in the USA, you would think it would be mentioned in this spec:
"ASAE S203.14 FEB2004 Front and Rear Power Take-Off for Agricultural Tractors"
It's not. They only show a 45mm/1 3/4" with 21 teeth.
Good luck.
11-26-2011, 08:09 PM #5Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,449
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
sounds like time for round stock and broaching..
11-26-2011, 08:14 PM #6
All i can find in the catalog are 20 spline 1-3/4" shafts and shaft adaptord. None of the 6 spline are this size
the manual alsoatates that rear pto (540 rmp) should be 6 spline; while mid PTO (1000 rpm) should be 20 splinecurrently own
2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
Quick Attach 79" loader mount snowblower & rear powerpack
Quick Attach 84" Snow Blade
Quick Attach 42" pallet forks
11-26-2011, 08:37 PM #7Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,554
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
Not sure if this is exactly what you are looking for, but follow this link, then choose Brakes/Axles/Trans. in the menu, then scroll down a ways. PTO shafts listed & pics...
If nothing else, maybe they can help you find what you need..??
VonsMog used Unimog parts
11-27-2011, 01:34 AM #8
G'day check out the bare co site i just had a quick look but could not find them on the US site but they are avail on the AUS site the number is B3725. Don't know why they are not avail over there but a call to them may be able to sort you out
Jon
11-27-2011, 12:16 PM #9New Member
- Join Date
- Oct 2011
- Posts
- 9
Try Tisco. I used to find a lot of odd sizes from them.
11-27-2011, 01:29 PM #10Platinum Member
- Join Date
- Jun 2002
- Posts
- 527
- Location
- Rozet, Wyoming
Baum Hydraulics part number 03-32-00398. 1 3/4" 6 spline 10" long. Pretty spendy at
$108.36 catalog price. 800-228-9288
Kim
Similar Threads
Jinma 284 PTO issues
By dunerdr in forum Chinese TractorsReplies: 5Last Post: 10-25-2011, 07:47 PM -
PTO shaft stuck/jammed on tractor
By IslandTractor in forum Owning/OperatingReplies: 86Last Post: 07-11-2010, 06:02 PM -
PTO drivetrain to 3/4" round shaft with 3/16" keyway - questions
By denisd in forum AttachmentsReplies: 14Last Post: 08-15-2008, 12:54 PM -
Look for Mid pto 10 spline yokes or complete shaft
By Old School in forum Kubota Owning/OperatingReplies: 0Last Post: 11-29-2007, 10:49 AM -
Bush Hog drive shaft adjustment, Repo
By BrettFF205D in forum YanmarReplies: 0Last Post: 03-13-2002, 10:29 PM
