Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Nov 2011
    Posts
    1
    John Deere 300X
    Default John Deere 300X w/Tuff Torx K46 tranny
    How do you remove the filler/vent pug on top of the tranny? It seems to be melted around the edges.
    Is a new one available from Tuff Torx?
  2. #2
    Silver Member RBLapham's Avatar
    Join Date
    Apr 2011
    Posts
    163
    Cleveland Tennessee
    John Deere X300
    Default Re: John Deere 300X w/Tuff Torx K46 tranny
    There are 2 plugs on the K46, one is a vent and the other is a filler plug which is flat on top. I just changed the oil in mine at 53 hours. To remove the filler plug use a sharp knife or box cutter, but you just get it under the edge of the plug enough to pry the plug up. Once removed there is a round coin looking magnet on the inside of the plug, clean it. Be very careful putting the plug back in with the magnet. Use 5W50 synthetic motor oil. On another tractor forum there is a write up with pictures on doing the oil change - search for K46 oil change and you should find it. Also if you pull the K46 out and change the oil be sure to release the parking brake - don't me how I know
    Deere X300, Plug aerator with winch, Deere 40 inch shovel
  3. #3
    Member 2manytoyz's Avatar
    Join Date
    Sep 2010
    Posts
    27
    Atwood, Ill.
    John Deere X475
    The write up RBLapham is referring in the other forum (PM me if you need to know name) is located in their John Deere stickies section at top of their JD lawn and garden forum. It's an excellant 'How To' post.
Similar Threads
  1. John Deere Prices 25-40 HP
    By Browns329 in forum John Deere Buying/Pricing
    Last Post: 07-29-2009, 12:02 PM
  2. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 04:03 PM
  3. Should I do Skid Steer or should I stick to regular John Deere?
    By FRIZ in forum John Deere Owning/Operating
    Last Post: 06-02-2009, 07:52 PM
  4. Kubota Glide Shift Tranny vs. John Deere PowerReverser
    By CWP37 in forum Buying/Pricing/Comparisons
    Last Post: 12-19-2006, 10:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
