Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Dec 2011
    Posts
    1
    CASE 580 C
    Default 580 c case backhoe with 207
    lookin for where the blockheater goes. this tractor has never had one installed . my napa store could not cross the part number i have so i am still looking for one.
  2. #2
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,213
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Default Re: 580 c case backhoe with 207
    I did a little looking, as I'm thinking of putting one on my 480C also. Went to Case Construction parts, and got a picture of the 207 block. It shows a 3/8" plug (#4) right around the engine oil dipstick area, that goes into the water jacket, looks like between #1 & #2 cylinders.
    I also did a search on the heater part number, and ran across the subject on another tractor forum site. One mentioned the element is a 3/8" thread, and 5 1/2" long element.
    The location of the plug appears to be the same on the 188, and 207 blocks. I've attached an exploded view of the 207 engine block, directly from Case Construction.
    Here is the part number for the heater A44815, and here is the power cord part number, A44814.
    I went to Messicks to see what the price of the element was. Shows $35.04, and the A44815 has been replaced by part A182030.
    I'd double check with a Case dealer mechanic to be sure. That is what I will do, unless the parts counter guy knows his stuff.
    Hope this helps..!!
    Attached Thumbnails Attached Thumbnails 580 c case backhoe with 207-001csc-147163-gif
  3. #3
    New Member
    Join Date
    Dec 2011
    Posts
    1
Similar Threads
  1. JCB vs Case Backhoe
    By AlanB in forum Construction Equipment
    Last Post: 03-13-2012, 03:07 PM
  2. Fuel Injection Pump for 1989 Case Backhoe 1st Gen
    By 1st gen 580k in forum Parts/Repairs
    Last Post: 05-16-2011, 03:54 PM
  3. Backhoe Case backhoe boom won't stay up
    By TXShelbyman in forum Case-IH
    Last Post: 04-28-2011, 01:27 PM
  4. Case 580 CK
    By REVTAYLOR73 in forum Parts/Repairs
    Last Post: 08-24-2010, 11:01 AM
  5. Case 580 Backhoe - Hard start
    By llewellynsd in forum Construction Equipment
    Last Post: 01-25-2004, 08:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
