Just got a 1975 Ford 3000 and have been having a leak in engine oil. The actual oil leak was discovered because of oil build up under the tractor in the rear below the hydraulic tank. The hydraulic tank was full of oil. After replacing the oil in the engine tank you could actually see rise of liquid in the hydraulic tank. Totally drained to hydraulic tank and replenished. Still losing oil in the engine and getting into hydraulic tank. What could be causing this? Tractor is an 8 speed diesel engine.
Thanks for any replies.
