John47
A short block is cheaper than a full engine, you have the carby, fuel tank, fly wheel etc.
I would never own anything but a Honda with Kawasaki coming in a close. I've had 2 Briggs take a dump on me. The Kolar engine on my tiller was put into service in 1973 and starts on the 3 pull and runs great.
Good thing is that parts for the Briggs aluminum engines are everywhere. IF you could locate a parts motor with a good bottom end (maybe an oil burner) you could build a good motor for nearly no cost but some time. Otherwise, the parts cost for new parts would be pointless.
There's a place called "Small Engine Warehouse" that sells new, new take-off and scratch & dent motors online.
Small Engine Warehouse - Repower Outdoor Power Equipment
Good news is most of these motors are generally the same bolt pattern and shaft length & diameter so you can make nearly anything fit if you have the skills.
