Results 1 to 5 of 5
  1. #1
    Join Date
    Apr 2003
    Posts
    2
    Default 1951 cub hyd problems
    hyd for back works ok but when I hooked up front end loader it would not raise bucket unless you raise or lower rear lift at same time.!! any ideas ??
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,553
    Texas
    Default Re: 1951 cub hyd problems
    Did it work normally in the past? Just a wild guess, but sounds like maybe some hydraulic fluid is not being properly routed. Are you sure the hoses are hooked up in all the right places? And can you post a picture of the rig?
  3. #3
    Join Date
    Apr 2003
    Posts
    2
    Cannot get picture at this time as tractor is in West virginia and Im in Ohio. Will be back down there soon . As far as I know the hoses are hooked up right .
  4. #4
    Join Date
    Jan 2002
    Posts
    221
    S.E. Michigan
    BX22, 1949 Farmall Cub, 1966 International Cub
    We'll definitely need more info.
    Loader type? Hose routing? Using a diverter block or blocking the rockshaft?
    I just sold an IH 1000 one arm loader which I restored and had mounted on my '66 IH Cub. See attached pic...Is that what you're talking about??? Chuck
    Attached Images Attached Images
  5. #5
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Sounds like the loader valve is in series with the rear lift. You probably need to put in a diverter valve, or a prioriy flow diverter to seperate the lift from the loader. You might want to check some of the Cub boards out there. Those guys really know Cubs.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
