Results 11 to 11 of 11
04-15-2012, 10:47 PM #11
Re: Tractor lift arm issues
G'day I think what you are talking about is the lower lift arm mounts and it is load sensing for the draft control. You can take the lift arm off and clean the shaft up and undo the two bolts and the bush housing should slide out,change the 'o'ring and refit
. You will need to drain the oil.
Jon
Similar Threads
Backhoe Jinma HW04 Framemount Backhoe For Jinma 454 issues
By KyleG in forum Chinese TractorsReplies: 30Last Post: 02-27-2009, 07:29 PM -
Snapped lift arm
By Makers_Mark in forum Mahindra Owning/OperatingReplies: 2Last Post: 03-14-2007, 02:18 PM -
Bent Grapple Arm - Reinforced it
By BobRip in forum Power TracReplies: 7Last Post: 03-09-2007, 10:15 PM -
Issues with Kioti Bachoe...anyone??
By shadoe in forum Kioti Buying/PricingReplies: 10Last Post: 06-08-2005, 10:38 AM -
Review and Issues
By nater in forum Power TracReplies: 19Last Post: 09-05-2002, 06:17 PM
