Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Veteran Member brain55's Avatar
    Join Date
    Jan 2008
    Posts
    1,824
    Brentwood, CA
    Default Re: Wheel broke off !
    Do yourself a favor and replace it with the axle from a B21. You will have to buy new studs too because they have screw-in studs rather than press-in. They are much stronger than the B7800 axles. I was responsible for a fleet of these machines all with foam filled front tires, when they broke I would replace them with the B21 axles and never have another problem. I was working for a landscape contractor and believe when I say these machines were abused.
    Brian
  2. #12
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,040
    Northern Vermont
    Kubota, Case, Deere
    I would also look at the other axle to see if it's showing signs of cracks.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  3. #13
    Member
    Join Date
    Jan 2012
    Posts
    38
    Pacific NorthWest
    Kubota B7800, LA402 FEL
    Quote Originally Posted by brain55 View Post
    Hey, Brian, thanks for the idea. I would definitely want something good and strong if I'm going to put the work into this.
    I'm looking at the parts list for both the B21 and the B7800, from the Messick's site. According to their parts list, the part number is exactly the same for both the B21 and the B7800. So is that a Messick's thing, that the parts would be exactly the same? Same part number, same price, everything.
    How did you find that your parts for the B21 were stronger? I would like that to be the case, because I would definitely like to go that direction.
    Thanks again.
    PCP
  4. #14
    Member
    Join Date
    Jan 2012
    Posts
    38
    Pacific NorthWest
    Well, it's over a year later, but I wanted to post the photos of my repair, since the thread that helped me most (http://www.tractorbynet.com/forums/k...apped-off.html) was so great with the pictures, and I figure one more example of a repair is always helpful.
    I'll probably post in a couple different posts, as there are a lot of photos. I'm doing an B7800 axle repair for dummies here.....
    OK, this is a bit awkward, and let's hope the thumbnails stay in order.
    1) the broken part(s) and the new hub, shown without studs in yet
    2) cleaning the old sealant off--why not do it in the comfort of a warm kitchen
    3) outer plate
    4) hub seated through plate
    5) seating the C rings--the guy at the tractor place said to put them in with lots of grease, like gluing them in so they stick tight
    6) seating the gear (yeah, getting that off originally was tough--used a 3 prong gear puller)
    7) placing the bearing
    8) seating the bearing, tiny taps
    9) oh, go to the next post
    Attached Thumbnails Attached Thumbnails Wheel broke off !-p4200021t-jpg   Wheel broke off !-p4200026t-jpg   Wheel broke off !-p4210036t-jpg   Wheel broke off !-p4210037t-jpg   Wheel broke off !-p4210042t-jpg
    Wheel broke off !-p4210045t-jpg   Wheel broke off !-p4210046t-jpg   Wheel broke off !-p4210050t-jpg
  5. #15
    Member
    Join Date
    Jan 2012
    Posts
    38
    Pacific NorthWest
    To continue B7800 Axle Repair for Dummies:
    1) Everything back, hopefully, in place, ready to re-attach
    2) Waiting tractor, great place to break down, couldn't have planned that one better
    3) Uncovered
    4) Close up
    5) Applying the sealant into groove--I don't get manicures
    6) Almost completely attached. Will fill with about a gallon of oil after this....
    7) Tractor, back in service !!
    Attached Thumbnails Attached Thumbnails Wheel broke off !-p4210051t-jpg   Wheel broke off !-p4210053t-jpg   Wheel broke off !-p4210054t-jpg   Wheel broke off !-p4210055t-jpg   Wheel broke off !-p4210058t-jpg
    Wheel broke off !-p4210060t-jpg   Wheel broke off !-p4220062t-jpg
  6. #16
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    great update and photos...great job!
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  7. #17
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,627
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Pictures are the greatest - Thanks.
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  8. #18
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    It looks like that old one had already been welded before you got it? Did it take this long to get the parts or just this long to get it posted?
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  9. #19
    Member
    Join Date
    Jan 2012
    Posts
    38
    Pacific NorthWest
    It took only about a week to get the part--the photos are from last year and they've been hanging around awhile. And it's possible it had previously been welded, yes, but I'm the 2nd owner.
  10. #20
    Super Star Member
    Join Date
    Apr 2002
    Posts
    10,083
    Northern Virginia
    Kubota ZTR and RTV
    You know your a true B7800 owner when you do this repair!
    Nice pics!
Similar Threads
  1. 3038e Front Wheel Assy Fell Off!!!
    By nunyabinis in forum John Deere Owning/Operating
    Last Post: 10-12-2011, 06:01 PM
  2. Dual Brakes on an HST tractor
    By Lockport in forum Owning/Operating
    Last Post: 07-06-2011, 10:58 AM
  3. 4 wheel drive question
    By new jersey mike in forum Owning/Operating
    Last Post: 07-03-2011, 11:22 PM
  4. SC2400 MM mower wheel parts
    By gordyy in forum Yanmar (New)
    Last Post: 05-26-2011, 07:30 PM
  5. Backhoe ck20hst front wheel drive shaft fell out
    By twade in forum Kioti Owning/Operating
    Last Post: 11-14-2010, 09:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
