Results 1 to 6 of 6
04-19-2012, 11:22 AM #1New Member
- Join Date
- Apr 2012
- Posts
- 3
- Location
- Gaylord, Mi
- Tractor
- 1951 Ford 8N
51 8N Starter Relay
Looking for some advice on removing the starter relay. The screws have been painted over and won't budge ( starting to strip ). Also would like to know correct connection for this relay. Positive ground with the relay, small connection facing block. Thanks !
04-19-2012, 01:14 PM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,124
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 51 8N Starter Relay
the oem relay, as you say is 3 terminal... small one faces the block.. the one nearest the starter lug is connected with the transfer bar.. the other gets the bat cable ( negative) as the positive cable is grounded , if an oem setup.
take a screwdriver.. a hollow ground one if you have it.. set it in the head and git it a couple sharp whacks with a hammer, then try to start taking them out.
04-19-2012, 02:41 PM #3New Member
- Join Date
- Apr 2012
- Posts
- 3
- Location
- Gaylord, Mi
- Tractor
- 1951 Ford 8N
Thanks for the input ! There are 2 wires ( 1 red, 1 yellow and the cable ) So the red goes to the small, block connection. Are the yellow wire and cable on the same post or are they split on the 2 remaining posts ( one with the transfer bar ) ?
04-19-2012, 04:24 PM #4
The wire color is irrelevant if the wiring has ever been modified or re-done. Which is a good possibility on a 60+ year old machine. But here is what I can tell you....and it helps to have an ohm meter....
Whichever post is connected with the battery cable (here is where the ohm meter is handy) gets the wire that goes through amp guage and on to the key.
The other one gets the wire comming from the starter button. According to the print I am looking at, wire to the amp guage should be yellow, and the wire to the starter button shoud be red with a blue tracer
As to the screws, try as soundguy suggested, but I have found that it helps to be applying a little twisting(loosening) pressure when you whack it with the hammer. Not sure if that is what he meant or not.
And if you are looking for an excuse to get a new tool, this would be a good time to look at an impact screwdriver. They sure are handy
".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
04-19-2012, 04:55 PM #5New Member
- Join Date
- Apr 2012
- Posts
- 3
- Location
- Gaylord, Mi
- Tractor
- 1951 Ford 8N
Thanks for the input ! I will give it a shot.
04-19-2012, 10:38 PM #6Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,124
- Location
- Central florida
- Tractor
ditto on the impact screwdriver. I use done earier this year taking hte rust tin apart on a 4000.. was a great help!!
Similar Threads
8N keeps breaking starter drives
By fibrostic in forum Parts/RepairsReplies: 11Last Post: 03-08-2012, 08:06 PM -
JD 1050 starter? wiring? operator?
By sarge1572 in forum Parts/RepairsReplies: 28Last Post: 11-19-2010, 04:25 PM -
R2500 Starter
By leekal in forum Mitsubishi/SatohReplies: 11Last Post: 04-25-2010, 06:41 PM -
Deere 318 starter issue
By cef2lion in forum John Deere Lawn & GardenReplies: 16Last Post: 11-03-2009, 08:59 AM -
Need help with our B2400
By mikeandbecky in forum Kubota Owning/OperatingReplies: 8Last Post: 12-07-2000, 03:59 PM
