Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    6
    monroe,washington
    mitsubishi
    Default front axle pin
    Thank you all for your help! I am new to tractors. I did have another ujoint farther back on the driveshaft that was just packed full with dirt making it hard to move the shaft. So, I have put the drive shaft together so far twice. Once it fell off towards the front and then another at the slip u joint. I get a couple loads and then it will pop off. I have noticed a pin up front holding my axle to the frame that has worked its way out. I am thinking this is causing the front to twist a bit causing the ujoints to pull apart. My problem is what is used to hold the large pin in. It has a plate on the front with a zerk fitting to hold it from going forward but nothing to stop it from working out to the rear. Any ideas would be awesome.
    Also, if you know of the nearest new tractor repair manual that is closest to this tractor please let me know.
    Thanks, Duane
    Attached Thumbnails Attached Thumbnails front axle pin-2012-04-22_16-55-11_76-a   front axle pin-2012-04-22_16-56-55_652-a   front axle pin-2012-04-22_16-57-43_787-a
  2. #2
    Join Date
    Dec 2008
    Posts
    88
    Marlboro,NY
    '50 8N, '67 & '71 ford 2000, 2010 Bobcat CT-235 TLB
    Default Re: front axle pin
    what model ford is this
    There's always time to do it right the second time!!
  3. #3
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,438
    Ararat Vic Aus
    G'day I would be taking that front plate off and having a look there could be a circlip popped off or it could be a stepped pin in which case the pin could be broken. In any case I would hold off using the machine until it is fixed.
    Jon
Similar Threads
  1. Ballast Front axle outer seal leaks
    By wrede in forum John Deere Owning/Operating
    Last Post: 05-03-2011, 08:36 AM
  2. Front Axle Pivot Pin Kubota
    By hdrider0_0 in forum Parts/Repairs
    Last Post: 08-12-2009, 10:46 PM
  3. Tires Tires sizes
    By Conservation in forum Owning/Operating
    Last Post: 12-26-2008, 09:26 AM
  4. Oil & Fuel 4120 Transmission & Front Axle Oil?
    By 8934 in forum John Deere Owning/Operating
    Last Post: 10-27-2008, 08:15 PM
  5. B7800 front axle vent modification
    By Muleskinner in forum Kubota Owning/Operating
    Last Post: 01-14-2004, 05:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
