You can order them from AgriSupply, also... Agri Supply - Search
Apr 29, 2012 / plow bolts #11 Redbug Veteran Member Joined Aug 9, 2004 Messages 2,118 Location Columbia, SC Tractor Kubota L3830HST You can order them from AgriSupply, also... Agri Supply - Search
Apr 29, 2012 / plow bolts #12 kevinj Veteran Member Joined Jul 5, 2003 Messages 1,421 Location West MI Tractor BX-1860, L3940HSTC, B7500, Farmall M, Farmall 560D mikehaugen said: you may be right, the ones that I cut off look more like the clipped head bolts. Click to expand... What type of hole is in the share??? The bolt must match. Whoever you bought it from should have the right bolts. If they are only 1/16 proud I would run it, if any more you have the wrong bolts. Also, do you have them tight enough???
