badbowtie
I have a older b7100 trator it is gear drive and I am thinking about 1981 but I was using it today with the bush hog on the back and was using the front bucket to rip out some trees before I bush hoged the small area. Well I had the bucket under the root ball and when I lifted it jerked the back of the tractor and I bounced in one good time and tree popped. But the bolts that are on the center piece were the shifter is that bolts to the transaxle sheered two bolts off. So I stopped because it had the front of the tractor and the back not very strong. I pulled of to the side and unhooked the bush hog and brought the tractor back up to the garage put a floor jack under the rear end and tryed to use a ratchet trap from rops far to front end loader to pull it back together. Loud pop and fluid all over the floor. Split that section about 8" crack right were the drain plug is. So I need to find that piece that bolts in front of the transaxle that has the shifter on top. It is only about 10" long but I need it. I am not sure how much parts will cost me to fix it. Or should I just sell the tractor 4' bush hog, 60" finish mower and grader blade. Just not sure what it is worth broke and buy a bobcat.
