Results 21 to 30 of 73
05-14-2012, 09:39 PM #21Member
- Join Date
- Apr 2012
- Posts
- 28
- Location
- digby ,nova scotia
- Tractor
- 1963 massey 35 SPECIAL photo cat driven 57or 55 GREEN ENGINE HARRY FERGUSON Z134
Re: metal piece came out of oil pan when changing oil
Thanks for the advice , thought the pictures might help . I took the rocker cover off .
everything looks fine but not sure . No missing piecies at least. I will probably have to take the oil pan off or sump. There may be more pieces like you say that didnt fall out yet. Now to figure out how to do that .wake me up when it stops raining until then let me sleep
05-14-2012, 09:56 PM #22Gold Member
- Join Date
- Jul 2011
- Posts
- 314
- Location
- SE Louisiana
When you get the oil pan off, check the oil pickup tube. It probably has a strainer of some sort and the piece may have come from there. The noise from the top end might be from lack of oil. You might have to take the rockers off and take a better look at the top end also.
05-14-2012, 10:30 PM #23Member
- Join Date
- Apr 2012
- Posts
- 28
- Location
- Tractor
Hello, Thanks for the reply . The rods mostly looked straight ,just a few looked sideways but lined up and still conected .thats maybe how they go I will have to learn as I go ' . There was quite a tap at a higher rpm not at idle ,when I parked it in the shed before I drained all the fluids. Now I can decide whether to take the engine completely out or just have a look once I remove the oil pan . this must come off without taking it all apart. looks to me if the part came from the bottom end or like you say from up a little higher.
05-15-2012, 08:17 AM #24Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,097
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
look at the top of the rocker assy again.. many setups have oil tubes with lil deflectors or holders that travel up and then across the rocker assy to oil the topside. might be something from one of them as well.
when you say rods sideways.. i assume pushrods? were they off their lifters?, ie.. kicked over at an angle a bit.. are the pushrods straight? doesn't take but a few thousands bend in them to make them shorter.. if they goet shorter that opens up clearance
05-15-2012, 09:20 AM #25Silver Member
- Join Date
- Mar 2004
- Posts
- 143
- Location
- South Central Ky
- Tractor
- Kubota M7040HD
You may have someone turn the the motor over by hand while you watch the valve train to see if everything is moving properly.
05-15-2012, 07:47 PM #26Member
- Join Date
- Apr 2012
- Posts
- 28
- Location
- Tractor
I will have another look and try to get a diagram for this engine . Thanks .
05-16-2012, 09:10 AM #27
look on the under side of valve cover , see if there are any simular parts. I think soundguy is onto something with his oil splasher theory.
05-16-2012, 09:23 AM #28Member
- Join Date
- Apr 2012
- Posts
- 28
- Location
- Tractor
Thanks, I will .
05-16-2012, 08:52 PM #29Member
- Join Date
- Apr 2012
- Posts
- 28
- Location
- Tractor
Got the oil pan . this is what was in it. the rest of the pieces.
05-16-2012, 09:04 PM #30Gold Member
- Join Date
- Jul 2011
- Posts
- 357
- Location
- Grantham, South East Queensland
- Tractor
- Kioti CK30 HST
HOLY COW!!!
Similar Threads
How efficient is synthetic motor oil to make.
By slowrev in forum Oil, Fuel & LubricantsReplies: 11Last Post: 10-29-2010, 09:07 PM -
Hows this for new oil discussion
By neucam in forum Oil, Fuel & LubricantsReplies: 5Last Post: 12-12-2008, 10:51 PM -
Oil & Fuel LK2554 - step x step : Changing failed oil seal in steering column
By DSinOR in forum Kioti Owning/OperatingReplies: 10Last Post: 10-14-2007, 10:23 PM -
2007 Chef of the Year Southest & Olive Oil
By rox in forum Family and Friends (Announcements & Notices)Replies: 8Last Post: 07-30-2007, 02:21 PM -
Oil & Fuel Motor Oil as the Hydraulic Oil in Power Trac
By DieselPower in forum Power TracReplies: 131Last Post: 05-19-2007, 08:28 AM
