Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Join Date
    Jun 2008
    Posts
    609
    N/A
    N/A
    Default Re: There's more than one way to break a tire bead
    I think ATV tires are the worst to break a bead on because the tire itself is so soft. I too tried my loader bucket unsuccessfully. About 10 years ago I was having a time of it with some ATV tires. After thinking about this problem over a cold one, it came to me! I have a dozer, why not use the blade as I was trying with my loader? Worked slick as a whistle! I could even do a couple at once. Now any time either myself or some of my friends need some beads broke, I just fire up the dozer!
    _____________________________
    John Deere 4700 - FEL & Backhoe
    McCormick C80L - FEL
    Bolens G152
  2. #12
    Join Date
    May 2005
    Posts
    970
    N. E. Florida
    The real secret is to use a lubricant.
    I always have some used mineral spirits from my parts washer. Just pour a little around the bead and let it soak in.
    Diesel fuel, kerosene and even gas also works
  3. #13
    Super Member JDgreen227's Avatar
    Join Date
    Nov 2003
    Posts
    6,722
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    Quote Originally Posted by farmeratheart View Post
    Dad and I used to break the bead on tires (haywagons, baler, rake, truck, etc) with the hydraulic drawbar on the back of his Farmall 200. The fast hitch generates plenty of downforce- just place the tire to be "unmounted" flat on the ground centered under the drawbar. Place a block of wood (~12" 2x4) with 2 square ends at the edge of the rim and up against the underside of the drawbar. Slowly lower the drawbar and the sidewall will be pushed away from the bead! Be careful not to use too long a block of wood or keep pushing after the bead is broken as you will raise the rear of the tractor off the ground with the hydraulic!
    Frank
    I don't know if my deere is typical of modern CUTS but my 3 point has no hydraulic down pressure.
    Always be willing to admit your shortcomings, there is no shame in not knowing how to do something. The shame is in NOT admitting you don't know how to do it.
    If you have a small truck, limit yourself to small loads, if you want to carry the big stuff, get a big truck.
    Never be ashamed of making a mistake. The only people who never (bleep) up are people who never try to do something new.
  4. #14
    Veteran Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    1,556
    Cumberland Plateau, TN
    Bobcat CT225
    Quote Originally Posted by JDgreen227 View Post
    farmerat heart was talking about an old Farmal 200. These had 2 point "fast hatch" with a 2 way cylinder on the arms. No 3rd point.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  5. #15
    Silver Member farmeratheart's Avatar
    Join Date
    Aug 2008
    Posts
    186
    MD
    JD2305
    That's right Dennis- I can't remember all the ways we used that drawbar as a makeshift press! Using it to fix tires was probably the most frequent- other than the use for which it was made- raising and lowering the hitch ...
    Frank
  6. #16
    Join Date
    Dec 2011
    Posts
    89
    Homemade
    Back in the day I used to break car tire beads with a bumper jack. Just put the edge of the base up against the rim and jack up on the rear bumper. Worked good.
  7. #17
    Elite Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    2,758
    Central Square, NY
    2615 HST FEL
    I have used the following methods that have been mentioned.
    A 2x6 on the tire as close to the rim as possible then driven my truck on the 2x6 to break the bead.
    I don't have a backhoe but the loader bucket edge to push the bead down also works.
    Large C Clamp with a piece of 1/4" thick flat steel.
    Bumper Jack.
    Now I just use a rim clamp tire machine I purchased.
  8. #18
    Join Date
    Nov 2003
    Posts
    6,722
    Central Michigan
    Quote Originally Posted by bigdeano View Post
    Those must have been in the days when cars had a REAL bumper made of steel, unlike todays flimsy plastic and aluminum crap. I have used a 6 ton bottle jack sandwiched between the tire bead and an old hitch receiver bar on the hitch of my GMC to break a bead on a wheel and tire assembly...it worked but I had to jack the rear of the GMC up a LOT further than I thought would be required...amazed me just how much pressure was needed to break the tire bead.
    Attached Thumbnails Attached Thumbnails There's more than one way to break a tire bead-029.jpg
  9. #19
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    2,785
    Nova Scotia
    Kubota L3400DT
    I use an attachment I built for my woodsplitter. Works like a charm.
    There's more than one way to break a tire bead-dsc00957.jpgThere's more than one way to break a tire bead-dsc00960.jpgThere's more than one way to break a tire bead-dsc00963.jpg
Similar Threads
  1. Tire Bead Seating ?
    By Gordon Gould in forum Parts/Repairs
    Last Post: 01-16-2011, 07:38 PM
  2. Tires Cheap Tire Changer for PT
    By woodlandfarms in forum Power Trac
    Last Post: 02-08-2009, 06:04 PM
  3. Slow Tire Leak
    By bindian in forum Owning/Operating
    Last Post: 10-05-2008, 10:00 AM
  4. Ballast Filling Rear Tires - Breaking Tire Bead?
    By gusg in forum Kubota Owning/Operating
    Last Post: 03-26-2007, 03:04 PM
  5. TURF TIRE PROBLEM BX2200 TITAN TIRE
    By KRECKER in forum Kubota Owning/Operating
    Last Post: 03-24-2004, 05:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
