Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Gold Member
    Join Date
    Oct 2010
    Posts
    381
    New Holland TC 29D
    Default There's more than one way to break a tire bead
    Recently I had to replace the valve stems on the BX1500 because they were cracked and dry rotted. Using the backhoe and a block of wood was the only way we could get tire beads broken, I'm sure there are other creative ways to do this.
    Attached Thumbnails Attached Thumbnails There's more than one way to break a tire bead-tire-dismounting.jpg
    TC-29D
    BX-1500
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Veteran Member Birdhunter1's Avatar
    Join Date
    May 2004
    Posts
    1,088
    Murphysboro, IL
    Ford 3910
    Default Re: There's more than one way to break a tire bead
    I had some 8" tires on my golf cart I changed a few weeks ago and used the pallet forks on my tractor to stab them to break the beads. I have also flattened the tires and run them flat till the beads popped, but these were all tires that I were not to be reused.
  4. #3
    Super Member JDgreen227's Avatar
    Join Date
    Nov 2003
    Posts
    6,737
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    I found this thread after doing a search here for tire bead breaking....I was trying yesterday to break the bead of a 1988 vintage 15 inch tire off a steel rim using the FEL bucket on my deere 4210...even with the tire deflated using either the edge of the bucket pointed down or when level the tire would just flip up when the pressure got to be heavy enough. Is it REALLY practical to use a FEL to break a tire bead?
    Always be willing to admit your shortcomings, there is no shame in not knowing how to do something. The shame is in NOT admitting you don't know how to do it.
    If you have a small truck, limit yourself to small loads, if you want to carry the big stuff, get a big truck.
    Never be ashamed of making a mistake. The only people who never (bleep) up are people who never try to do something new.
  5. #4
    Super Member
    Join Date
    Mar 2008
    Posts
    6,620
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    In my experience, you have to roll forward while pushing down or it will flip the tire before breaking the bead.
    Aaron Z
    These questions should not be assessing our students’ ability to decipher convoluted language. Instead, they should be assessing deep understanding of core concepts.
    http://www.washingtonpost.com/blogs/...-tests-failed/
  6. #5
    Join Date
    Nov 2003
    Posts
    6,737
    Central Michigan
    Quote Originally Posted by aczlan View Post
    Aaron Z
    And to me that seems like an excellent way to damage what may be a very expensive rim....
  7. #6
    Super Member
    Join Date
    Mar 2008
    Posts
    6,620
    Quote Originally Posted by JDgreen227 View Post
    With our B7500 and a haywagon rim that I was putting a tube into, I rolled forward ~1.5" while I was pushing down on the tire to compensate for the arc of the loader going in toward the tractor as it goes down. The lip of the bucket then stayed on the bead and did not slip off like it was doing before I started rolling forward. You could also use the curl function to the the same thing.
    IMO, it would work better if the rim was fastened to something immovable so that it couldn't flip.
    Aaron Z
  8. #7
    Join Date
    Nov 2003
    Posts
    6,737
    Central Michigan
    I have always wondered why nobody seems to market a really large C-clamp unit that would serve to pop a bead on a large tire. Using a clamp is my favorite method for smaller tires such as those found on the rear of L&G tractors.
  9. #8
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    35,291
    Texas
    In addition to the FEL, I've also laid a tire & wheel down and driven a car or pickup onto the flat tire just as close to the rim as possible. That always worked, too.
    Bird
  10. #9
    Join Date
    Nov 2003
    Posts
    6,737
    Central Michigan
    Quote Originally Posted by Bird View Post
    Bird, I have tried using a wheel on my tractor to drive over a tire bead but most of the time the tractor tire simply shoves the horizontal tire away instead of climbing atop it. Later today I am going to try using a steel car ramp straight section and see how that works when Idrive up on it.
  11. #10
    Silver Member farmeratheart's Avatar
    Join Date
    Aug 2008
    Posts
    198
    MD
    JD2305
    Dad and I used to break the bead on tires (haywagons, baler, rake, truck, etc) with the hydraulic drawbar on the back of his Farmall 200. The fast hitch generates plenty of downforce- just place the tire to be "unmounted" flat on the ground centered under the drawbar. Place a block of wood (~12" 2x4) with 2 square ends at the edge of the rim and up against the underside of the drawbar. Slowly lower the drawbar and the sidewall will be pushed away from the bead! Be careful not to use too long a block of wood or keep pushing after the bead is broken as you will raise the rear of the tractor off the ground with the hydraulic!
    Frank
Similar Threads
  1. Tire Bead Seating ?
    By Gordon Gould in forum Parts/Repairs
    Last Post: 01-16-2011, 07:38 PM
  2. Tires Cheap Tire Changer for PT
    By woodlandfarms in forum Power Trac
    Last Post: 02-08-2009, 06:04 PM
  3. Slow Tire Leak
    By bindian in forum Owning/Operating
    Last Post: 10-05-2008, 10:00 AM
  4. Ballast Filling Rear Tires - Breaking Tire Bead?
    By gusg in forum Kubota Owning/Operating
    Last Post: 03-26-2007, 03:04 PM
  5. TURF TIRE PROBLEM BX2200 TITAN TIRE
    By KRECKER in forum Kubota Owning/Operating
    Last Post: 03-24-2004, 05:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
