JD 4410 Have A,B but No C Gear. Code .--.
   / JD 4410 Have A,B but No C Gear. Code .--. #1
imprezawrx2008
Panama City, Fl
JD 4410
Ok, so I had to join cause I can't find info on this at all! I have a JD 4410 e-Hydro. Last weekend I had to change a left rear axle seal. What a job for a seal! Everything seemed to work good. But today I was going to drive to a property down the road, but I have no C gear! I checked the linkage, it was fine. Wasn't in the way of the Axle Seal repair job, so it was untouched. Now I also get code .--. which by researching its the MFWD sensor. Checked all wires underneath. Everything's fine. I have A, B, N, and when it goes into C it's like it's in Neutral. Can hear a little light whine but no go. I hope nobody has had this problem, but I do hope someone can help me fix this! Thanks!
   / JD 4410 Have A,B but No C Gear. Code .--. #2
That code is showing as a MFWD fault. Try turing off your MFWD switch and restart tractor. Hopefully that should reset it and alow C range to work.
5 • - - • MFWD Speed Sensor
Normal Operation:
Fault Cause:
Output current exceeds a certain value without detecting an MFWD
speed. Engine speed must also be available at same time.
Machine response:
Cruise control will be disabled; loss of performance.
Reset:
Power recycled through off to clear error status.
Calibration Routine:
Fault Cause:
Missing MFWD speed or signal exceeds rpm tolerance.
Response:
Calibration routine stops.
Reset:
MFWD signal has to be available. Calibration repeated.
   / JD 4410 Have A,B but No C Gear. Code .--. #3
Symptom: Range Transmission Problems
(1) Range Transmission Does Not Engage?
Yes - Cogs on gear or shift collar damaged or worn / no longer serviceable.
Yes - Drive shaft gear or counter shaft gear worn / no longer serviceable.
Yes - A/B/C gears worn / no longer serviceable.
Yes - Shift linkage worn or damaged.
(2) Range Transmission Will Not Stay Engaged?
Yes - Detent ball spring broken.
(3) Range Transmission Noisy In Neutral?
Yes - Low/medium/high gears worn / no longer serviceable.
Yes - Bearings on pinion shaft/counter shaft worn or damaged.
(4) Range Transmission Noisy In Gear?
Yes - Pinion and ring gear worn or damaged.
(5) One Gear Will Not Engage?
(6) Differential Noisy?
I've tried that. Even tried disconnecting the battery for 10 minutes. The code will only blink when I put it in C and push the pedal. I can drive it around in A and B with no code. It feels like it's not engaging in C, almost like it's in Neutral. When I put it in C it'll roll. Just adjusted the linkage a little more. No go.
Oh man #5 don't sound good! I didn't even touch that far back for the seal replacement! Here's some pics of the job. Everything went back together smoothly. So I think.
Does anyone have a picture of the range selector gears?
