Results 1 to 3 of 3
  1. #1
    Member
    Join Date
    May 2012
    Posts
    27
    Wattsburg Pa
    1940s mccormick deering 0-4, 170 allis chalmer, 950 john deere, 7030 and 7040 allis chalmer 986 international
    Default 170 allis chalmer cooling problems
    i rebuilt a 170 allis chalmer, i put all new pistons, sleeves, bearings, crank and seals in. i started it an it ran for a hour or so then i turned it off and started it again and the water in the radiator came all bubling out the top. the only awnser i could think of was the new water pump was craeting more presure than the radiator could handel. any ideas????
  2. #2
    Veteran Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    1,806
    Western Montana
    New Holland TD95D, Ford 4610 & Ferguson TO-30
    Default Re: 170 allis chalmer cooling problems
    Quote Originally Posted by nattynuts5886 View Post
    Several possibilities. I wouldn't suspect the new water pump.
    Did you check the cylinder head for warpage when you removed it? If it's not within about 0.002" of being flat, you could have some leakage from the head gasket. Did you correctly( pattern AND torque ) torque the head down with the new gasket? I always retorque the head after running it for an hour and bringing it to operating temperature.
    With the engine runnning and at operating temperature (thermostat open) do you see streams of tiny bubbles continuously forming in the coolant? That's the sign of a head gasket leak.
    Did you fill it with coolant without the thermostat housing on, or without the thermostat installed so you didn't trap a bunch of air in the head or the cooling jacket?
    Finally, most raditors without an overflow bottle require filling to about 1/4" above the rad core to allow for coolant expansion when it heats up. Filling it higher that this will result coolant running out the overflow.
  3. #3
    Member
    Join Date
    May 2012
    Posts
    27
    Wattsburg Pa
    thanks, got new radiotor cause other one was to leaky and it sloved my problem no head leaks and sealed up real nice
Similar Threads
  1. Boomer Problems
    By froggy in forum New Holland Owning/Operating
    Last Post: 04-26-2013, 09:22 PM
  2. 955 cooling system problems
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 11-29-2002, 06:35 PM
  3. JD 4000 series wheel bolts
    Last Post: 04-13-2002, 10:56 AM
  4. Chain of command
    Last Post: 04-13-2002, 06:17 AM
  5. AGCO Allis info
    By Owen in forum All Other Brands
    Last Post: 07-02-2000, 10:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
