alchemy
This could be for discussion for anything to do with belarus starters but here is my problem.
I got this starter for my 1979 250 AS and it does not fit. The ad clearly states for 1979 250 AS .
NEW STARTER BELARUS TRACTOR 250 300 400 400A 405A 420A 425A SBE0003 | eBay
This starter has a nose/bendix opening that is too far counterclockwise if facing the nose side. It hits the flywheel while the bolt holes are about 1/4" from lining up. Actually the bendix opening should be about 30 deg CCW from where they have it. The nose length and width are smaller also and the gear sets out a little further. Measuring the flywheel teeth to mount face and that of this starter it looks to me as it would still work, leaving about 3/16" between the flywheel teeth and the bendix gear with the solenoid at rest, as long as I could get the holes to line up. I have a couple ideas to try since they require me pay return shipping and then it's at their discretion whether they want to refund or not.
Even though they print that it fits a 250 AS 1979 in bold print at the very beginning there was nothing about nose differences and then they print later and smaller "must match part numbers." Well I could not read part numbers but after closer inspection later I saw CT222 a distant "T" then more bizarre characters. They state CT222A .
I may try to just cut a 1/2"X 1 1/14" rectangular slot at the edge of the nose where the flywheel, redrill bolt holes, or make a mounting adapter of some sort. I also considered just switching the mount face and nose with my old one but I think the shaft length is different.
Please post your knowledge, experience, or ideas if you have any.
