Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: bad alternator?
    a multimeter would likely tell you whats wrong... but yeah.. store should be able to test it..
    ps.. oem alternator # is SBA185046180
    reg is SBA185516030
  2. #12
    Bronze Member moojamboo's Avatar
    Join Date
    Mar 2011
    Posts
    92
    Nothern Vermont
    Ford 1710
    so i say we have an external regulator...but i can't seem to locate it. in the manual it shows a regulator separate from the alternator any ideas where i would look for it?
  3. #13
    Join Date
    Mar 2011
    Posts
    92
    Nothern Vermont
    Ford 1710
    Thanks Soundguy....if the alternator is factory 1986 is it worth rebuilding? are there specialty places where they rebuild alternators? is there a good place to get ford parts online?
  4. #14
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    most towns have mom n pop stores that do gen/alternator and starters. IF it even needs a rebuild.. might be just a 40$ reg.
    look behind the instrument cluster for that reg...
  5. #15
    Join Date
    Mar 2011
    Posts
    92
    Nothern Vermont
    Ford 1710
    is there a way to test if the regulator is bad with a mulitmeter?
  6. #16
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    you can OBSERVE if the reg is bad, using hte meter and the alternator..etc
  7. #17
    Join Date
    Mar 2011
    Posts
    92
    Nothern Vermont
    Ford 1710
    i'm fairly new at electrics...is there a way to isolate and test just the regulator? i took the alternator around today and couldn't find anywhere which would bench test the alternator (autozone said they couldn't cause they wouldn't have a part number). so at this point i don't know how to separate the regulator from the alternator in the circuit while trying to diagnose the problem.
    how do i tell a regulator issue from an alternator issue with a mulitmeter?
  8. #18
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    if you can't test the alt.. it may be pointless.. if the alt was tested good, then you could infer regualtor issues if it did not charge.
    find a REAL alternator/starter/generator rebuilder.. they will be able to test it..
  9. #19
    Super Member deerseeker001's Avatar
    Join Date
    Jul 2011
    Posts
    7,878
    Central wisconsin
    International 2500a with Loader
    i went through this took my alternator to a good electric repair shop tested the out put said it was good.this alternator was a 3 wire i went to a 1 wire alternator and now it works fantastic.
  10. #20
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    sounds like you had a generic delco 10/12 SI model.. not the oem tractor alt... BIG difference....
Similar Threads
  1. Smoking Alternator Wire
    By ctmeans in forum Yanmar
    Last Post: 05-24-2012, 05:07 AM
  2. Bad alternator Ford 1300
    By jvigier in forum New Holland Owning/Operating
    Last Post: 05-19-2012, 08:46 AM
  3. Voltage Regulator
    By matthoffman33 in forum Chinese Tractors
    Last Post: 10-31-2011, 11:53 PM
  4. Converted 2520 wannabe 20amp alternator to a real 45amp
    By 2305JD in forum John Deere Owning/Operating
    Last Post: 01-31-2010, 11:27 AM
  5. Ford 1720 Alternator
    By EricinTN in forum New Holland Owning/Operating
    Last Post: 11-19-2004, 06:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
