Treemonkey1000
As all above have said are things to look at. Also look at if it has a windvane type governer. Get a can of carb cleaner and spray all of the linkages. First blow or brush off any debris from the linkage. If you are spraying carb cleaner while it is running and you get it to start acting up look for gasket leaks between the carb and intake port.
