800 ford tractor
   / 800 ford tractor #1
DarrellT
Columbia City, Indiana
800 Ford
I am looking for a new steering gear box or information on how to rebuild the old one. The wheels will turn right but when turning left the steering column screws out to the stop without the wheels turning. I have removed the outer shell of the column and can see the worm gear on the bottom turn left as it unscrews from the botton plate. Confused what the problem is?????????????? Thanks
   / 800 ford tractor #2
classic sign of worn or now missing upper thrust bearing.
unless the box is worn slap out, it's a simple job to buy 2 thrust beairngs, and races if needed.. pull box apart, add new bearings.. clean out old box .. may have rollers in it.. repalce sector bushings and seals if needed.. put box back together and re-time it.. and then put box top on adjusting shim stack for correct preload on thrust bearings.
then I'd reccomend pumping it full of 0 or 00ep grease ( jd cornhead, snapper, stens.. etc. )
takes about an hour to R&R the box if you already have it down tot he point you can get the steering column off.
a rebuilt box is about 600$ plus shipping when I looked ayear ago.
I've rebuilt plenty of them boxes.. probably every ford I have with manual steering from 52-63 has had it's box rebuilt.
you will want the I&T fo-20 manual if you want a step by step instruction to retime the gears.. otherwise, if you can count to double digits you can figure the retime...
soundguy
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2013 Ford F-150 (A53422)
2013 Ford F-150...
20" Sea Container (A47384)
20" Sea Container...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
