Results 1 to 10 of 18
06-30-2012, 09:30 PM #1
Any way to revive an unused, but older battery?
4 years ago I bought a new battery for my boat. It's one of those massive dual purpose start/deep cycle batteries. I ended up selling the boat before I used the battery, so it has sat on a shelf for 4 years. I recently tried to charge it, but it won't hold enough charge to start my tractor (the use I was hoping for it, now).
Is there any means to bring it to life? I know it isn't used up, as I've never even used it. It cost me over $100, and I'd hate to have to throw it out. Am I screwed or is there hope for it?
06-30-2012, 09:56 PM #2Silver Member
- Join Date
- Sep 2007
- Posts
- 246
- Location
- Texas
- Tractor
- Mahindra 2810, IH Hydro 70
Re: Any way to revive an unused, but older battery?
not sure how you charged it, but I would put a 2amp charge on it for how ever long it takes (depending on size could take 12-24hrs or more). I have had "dead" batteries come back to life using a 2amp charge instead of 8 or 10 amp.
Also if it was completely dead you may need to jump it to get an automatic charger to even start charging it.
06-30-2012, 10:01 PM #3
Thanks texan! I had no idea there was a difference in charge time for size. I thought all lead acid batteries charged in the same amount of time. I only charged it for about 7 hours at 2 amps. I was afraid of doing damage to it by overcharging, but apparently I didn't nearly charge it enough.
If the temp ever drops below 100F I'll throw it back on the charger for a full day. I really hope I can use this, as it seems like it will be perfectly suited for my tractor.. plus it adds some nice ballast to the front end
06-30-2012, 10:21 PM #4Elite Member
- Join Date
- Mar 2002
- Posts
- 2,790
- Location
- Iuka Mississippi USA
- Tractor
- 3550 Fard Backhoe and a 1948 Farmall Cub,
They sell a special slow charger called a pulse charger Im looking to buy one for the shop at work as we go through alot of batteries.
07-01-2012, 12:09 AM #5
It's always been hit or miss when trying to breath new life into a dead battery. I think it comes down to two things, the first is how many times it was drained flat and the second being how long it was left dead before trying to recharge it. I have had some luck with a desulfating charger but they are not cheap. I would just leave a trickle charger on it for a couple of weeks.
Kubota L4240,Case 580K backhoe, Case 450 Dozer
07-01-2012, 12:22 AM #6Gold Member
- Join Date
- Jun 2011
- Posts
- 258
If it is not a sealed battery, make sure to check the water/acid level. Fill it with real distilled water.
07-01-2012, 01:06 AM #7Veteran Member
- Join Date
- Nov 2011
- Posts
- 1,084
- Location
- Near Winnipeg, Mb, Canada
- Tractor
- John Deere 2305, 2320,Z465
What about warranty? Do you have the receipt? Even prorated you should get most of your money back to put towards a new one. Good luck.
Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
07-01-2012, 02:02 AM #8Silver Member
- Join Date
- Sep 2007
- Posts
- 246
- Location
- Texas
- Tractor
yep, assuming you have an automatic charger (majority are now days) leave it on until it says its done charging... I have had a dead lawn mower battery take about 5 or 6 hours and a pretty low car battery (sitting for 6 months still hooked up) take over 24hrs (i was surprised to see it only at about 65% charged when I checked it the next morning which was about 12hrs after i hooked it up). This is on an automatic charger that says when it is fully charged. I have never used a manual charger before so if you have a manual one that may be different.
07-01-2012, 03:41 AM #9Veteran Member
- Join Date
- Sep 2010
- Posts
- 1,307
- Location
- kodiak island, Alaska
- Tractor
- kubota L2800, 1/2 of a L48
Sometimes you have to hit it with the boost charge to get it to take a charge, dont do it too long tho couple minutes max.
You can find those smart chargers that will desulfate and bring back old batteries for under 60 bucks now also.Rick
07-01-2012, 08:50 AM #10
Any lead acid battery will loose charge when not used for long time. Charging at low amps for longer time will bring battery closer to its full charge then higheramp for short time. Also let the battery set for 30 minutes after recharging with charger disconnected before testing or using.
Dennis
CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
Similar Threads
How to revive an old (very old) blueberry patch
By Piston in forum Owning/OperatingReplies: 11Last Post: 06-27-2011, 09:23 AM -
Older 350B not charging battery (drawing down)
By JAY AND EBBEN in forum John Deere Owning/OperatingReplies: 3Last Post: 05-20-2011, 07:51 PM -
When to brushhog unused field?
By JimS in forum ProjectsReplies: 10Last Post: 08-26-2010, 12:37 AM -
What to do with unused field ?
By pennwalk in forum Rural LivingReplies: 10Last Post: 04-25-2006, 02:23 PM -
unused wiring????
By JD3520 in forum John Deere Owning/OperatingReplies: 8Last Post: 08-27-2005, 08:59 PM
