Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    1
    VICTORIA
    FORD 6640
    Default 6640 ford hour meter not working
    My hour meter is not working at all. I am told it get signal from alt but purchased tractor used so don't know any history on it. The alt looks like it might be an aftermarket unit Magnet Marelli 54022397A. Every thing else works including the pto and tach. Thanks for any help in advance!
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,316
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Default Re: 6640 ford hour meter not working
    If the PTO and tach work but the hour meter doesn't, the hour meter is junk. Will require replacement of the instrument panel and depending on your tractor's build date and panel type, may require more than just the IP.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
Similar Threads
  1. Tachometer and hour meter not working
    By RMJ22 in forum John Deere Ag Tractors
    Last Post: 02-16-2012, 08:38 AM
  2. hour meter not working
    By natem in forum Kioti Owning/Operating
    Last Post: 12-03-2007, 07:01 PM
  3. Hour meter stopped working
    By mjym in forum Kubota Owning/Operating
    Last Post: 12-27-2005, 08:23 PM
  4. hour meter not working
    By andystix in forum Parts/Repairs
    Last Post: 02-25-2004, 09:52 PM
  5. Hour Meter Stopped Working
    By MikePA in forum New Holland Owning/Operating
    Last Post: 11-22-2003, 01:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
