Page 1 of 18 123411 ... LastLast
Results 1 to 10 of 172
  1. #1
    Join Date
    May 2012
    Posts
    177
    bfe
    in search of new iron
    Default j.i. case 1949 SC
    i have a 1949 case row crop tractor narrow front end i need to put gear oil in her but the front break leaks these are the old style break pedal on each side with the cylinder on the tractor it has a lil leak i cann;t find a replacment part for it my guess it is just a bad seal but i cant find one anyone any suggestions on what to do JB weld HER?
  2. #2
    Super Member
    Join Date
    Apr 2000
    Posts
    6,588
    central New York
    all makes and models
    Default Re: j.i. case 1949 SC
    Have you tried a Case dealer?
  3. #3
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,193
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Below is an exploded view of the differential of your SC directly from the Case/IH site. The only seals shown behind the brakes are in the differential bearing carrier. Through Case/IH, those seals are $27.14 ea. Through Saeli Implement they show a couple of prices. One is $12.70, and another I saw was $14 and change. They (Saeli) also carries the gasket and O-ring for the bearing carrier.
    Discs unless worn out, can be cleaned up. An old Case collector showed me how to take a propane torch and "boil" the oil out of them. I chose to hang them on a piece of #9 wire, and held the torch a couple inches from the disc, and go in a circular motion on the surface of the disc. Oil will literally boil out of the disc surface. It takes a while, so be patient. I further cleaned with brake parts cleaner, then buffed with a roloc pad, on my air angle grinder. A medium gasket removing disc works great.
    Pretty much the same brake setup on my old 310B I had. It is recommended in the repair manual, to only do one side at a time, or it will let the differential drop in the diff. case.
    The 310B had large Phillips head, bevel headed screws to hold the bearing carrier in. I replaced them with a hex type, bevel screw, so as to make reinstallation a lot easier, since they need to be torqued. Even though as I recall it was only like 10-15 inch lbs. No cam out on the screw heads.
    Hope this helps..!!
    http://www.saeliimplement.com/index....emart&Itemid=3
    j.i. case 1949 SC-sc-case-differential-gif
  4. #4
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    DJ54 is correct. Be careful when you are removing the cover not to loose or damage the shims that are between the cap and housing and the felt washer that goes against the cap.
  5. #5
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    nice looking machine in the avatar. i always thought the front pedistal on em looked interesting..
  6. #6
    Join Date
    May 2012
    Posts
    177
    bfe
    so what should i do just get the axel/diffrentel seal and replace it and leave it
  7. #7
    Join Date
    May 2012
    Posts
    177
    bfe
    so what should i do just get the axel/diffrentel break seal and replace it and leave it
  8. #8
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Quote Originally Posted by Soundguy View Post
    nice looking machine in the avatar. I always thought the front pedistal on em looked interesting..
    Thanks Soundguy
    So what should I do just get the axel/diffrentel seal and replace it and leave it
    You should replace the seal but also while you are in there check the bearings. They are adjustable tapered roller bearings. There is one at the end of the housing and one on the transmission casting. To fix any play in them you will have to add more shims. The hardest part of changing them is getting the rear wheel off as it has some weight to it.
  9. #9
    Join Date
    May 2012
    Posts
    177
    bfe
    the axel diffrential seal is the one i need for sure before i order it?
  10. #10
    Join Date
    May 2012
    Posts
    177
    bfe
Similar Threads
  1. 1949 Ford 8N
    By kvan in forum Ford Vintage Tractors
    Last Post: 05-25-2012, 05:07 PM
  2. correct 1949 8N hood
    By cfb in forum Owning/Operating
    Last Post: 05-11-2012, 06:39 PM
  3. 1949 Case DC Value ?
    By Frankm in forum General Vintage Tractors
    Last Post: 04-24-2006, 01:55 PM
  4. 1949 8N Tractor
    By proberly in forum Parts/Repairs
    Last Post: 11-23-2004, 03:16 PM
  5. 1949 Pony
    By hughes in forum Rural Living
    Last Post: 09-22-2004, 01:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
