FergFan
Member
This is a pic of the 12v alternator on my TO30 Z129..it doesn't fit the description I'm getting from some as far as the P1,P2, and BAT connections. What I'm seeing is a BAT, GRD, and FLD..and a STA that never had anything hooked up to it before. I'm quite a newbie and am just trying to wire the alternator the way it was previously..which was...
Alternator GRD - grounded to one of the four bolts on the gear shift starter switch
Alternator BAT - ran it along battery cable to positive battery post
Alternator FLD - to a voltage regulator(Echlin VR32) then out to L on dash ignition switch
This Voltage Regulator has only two connections..one labeled Field on the RH side and one labeled ignition on the LH side
