I've got a leaking seal on the front axle driveshaft input seal.
I got the part on order so I have not seen the part and I have the drive shaft removed so I can see the seal but it's not clear how the seal comes out.
Per the manual the instructios are not clear if the seal can be replaced itself or if I have to remove the input shaft from the axle housing and then replace.
Any thoughts?
Any thoughts?
