Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    19
    Philomath, OR
    IH 424
    Default Surging
    My IH 424 (Gasser) is surging on me. It only seems to do it once it is really warmed up (10 minutes or more of use with a decent load). Feels like somebody is pumping the gas in a car. I've replaced the fuel pump, coil, installed a ballast resistor (PO had removed the original), changed fuel filters, cleaned carb inlet filter and float bowl. It's been an ongoing proplem http://www.tractorbynet.com/forums/p...ml#post2890842 anybody have any new thoughts? I'm thinking it has something to do with the mechanism that increases fuel as load on the motor increases, but I have no idea how that works. If anybody can give me a quick education on that it would be greatly appreciated as well.
    Thanks,
    Nick
  2. #2
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,193
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Default Re: Surging
    If it is surging rather quickly, sounds like the governor is doing what they call, "hunting". Past experience has taught me it can be lack of fuel, and the governor will respond by opening the throttle to recoup lost RPM's, or there is wear in the Gov. assembly.
    The thrust bearing inside the gov., that actuates the cross shaft is notorious for going bad over a long period of time. The cage that holds the small ball bearings, will let the little ball bearings drop out, and you will have slop between the actuator, and cross shaft, and may cause something like this. I know when they completely come apart, the engine will not go above approx. 1/3 throttle.
    Check for slack in your gov. control rod by unhooking from the carb. There's probably a little, but not supposed to be much. Be careful of the little arm on the carb side. They used to be potmetal, and easily break. A spring in the gov. housing is supposed to hold it within tolerence. There is a small adjusting bolt on top of the Gov. housing, to adjust the Gov., to keep from "hunting". I believe even an I&T manual shows the adjustment procedure.
    It' not hard to check the bearing condition. Just pull the front cover off the Gov. assy., and you're looking at it. It rides on a shaft, behind the two fingers on the cross shaft. You used to be able to buy that little bearing for 75 cents years back. Last I bought was around $8.00 if memory serves me right. Also check the condition of the control spring. If it is worn in the hooks, replace it. If if breaks, it will allow the engine to run away.
    I've attached an exploded view of the Gov. assy. from Case/IH to give you an idea of what you will be looking at.
    Surging-ih-424-gov-assy-gif.
  3. #3
    Join Date
    Jul 2003
    Posts
    1,926
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Default Re: Surging
    True, it may be your gov., or it may be as simple as opening up the high speed needle another 1/4 turn...I've got a Farmall 140 that runs beautifully until you put it under heavy load and then it started to "hunt"...I opened up the "big screw" on the front of the Zenith carb 1/4 turn and it was fine..give it a try..let us know. BobG in VA
  4. #4
    Elite Member
    Join Date
    Sep 2008
    Posts
    4,763
    NE USA
    JD LA115, WH 244, Troy Built Horse 8 HP
    Default Re: Surging
    If your surging is like most, the fuel supply is being starved and the
    unit needs a new fuel filter or the tank has a lot of crap in it and needs to be cleaned out.
  5. #5
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,606
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Default Re: Surging
    Check the mixture setting on the carb. Too lean can cause surging.
    Some governor housings have a damper screw to put added friction damping in the governor and desensitize it. If you have one on your governor, you might see if screwing it in helps.
  6. #6
    New Member
    Join Date
    Apr 2012
    Posts
    19
    Philomath, OR
    IH 424
    Default Re: Surging
    I thought I had her licked, but after 1.5 hours of mowing she started acting up again. Came on a little slow but was surging pretty good off and on within a couple minutes of the first hick-up. It looks like I cracked my carb where the fuel line screws in, so I guess I'll put a new carb on and see if that helps. Unless anybody knows of a way to fix that? It's seeping just a tiny amount of fuel around the screw in fitting and has a small crack.
Similar Threads
  1. Surging engine
    By Gixxer in forum John Deere Lawn & Garden
    Last Post: 07-16-2012, 07:41 PM
  2. 3-Point Hitch Surging in up position
    By Deere Dude in forum John Deere Owning/Operating
    Last Post: 11-24-2011, 10:32 PM
  3. Idle Surging
    By EddieWalker in forum Parts/Repairs
    Last Post: 07-22-2011, 07:21 PM
  4. Engine surging?
    By smstonypoint in forum Snapper
    Last Post: 07-13-2010, 06:49 PM
  5. TC-30 surging
    By Ken_W in forum New Holland Owning/Operating
    Last Post: 05-10-2006, 10:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
