Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2011
    Posts
    4
    Ford 8N
    Default John Deere 4110 power steering cylinder
    I have 2 questions:
    John deere 4110 power steering cylinder P# AM879356
    Does anyone know if there is an aftermarket cylinder to replace this? I've only seen new OEM ones @ $600.00 give or take.
    Ford 8N
    I'm looking to get a new Marvel updraft carb for it. Where is the best place to get one and do I have to stick with the original Marvel Schreiber?
  2. #2
    Elite Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    4,104
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Default Re: John Deere 4110 power steering cylinder
    Quote Originally Posted by Mike Dermott View Post
    to replace this?
    Here is a replacement JD 955 steering cylinder, recently completed using a generic cyl
    from SurplusCentr, with a couple of NAPA tie rod ends welded on. Total parts cost
    was <$150.
    I would not buy any JD cylinder, but that's me. If you don't weld, then you can
    buy the parts and have a shop do it.
    Attached Thumbnails Attached Thumbnails John Deere 4110 power steering cylinder-steering_cyl.jpg
    See my TBN projects at:
    http://mysite.verizon.net/resyfcgt/
  3. #3
    Join Date
    Jul 2004
    Posts
    1,553
    Bancroft, Ontario
    JD4300
    The cylinder on my JD4300 failed while plowing snow a few years back and when I pulled it off, found that it was non-rebuildable. When I called my dealer he offered me the "rebuild kit"???? Found that the cylinder has been upgraded to a rebuildable unit, available the next day.....Price was JD but not THAT bad.
    My cylinder had come apart internally and the rod fell out. Not real easy to tow a JD with no steering and the cylinder removed......
  4. #4
    Join Date
    Feb 2004
    Posts
    4,104
    NorCal
    Quote Originally Posted by pat32rf View Post
    few years back and when I pulled it off, found that it was non-rebuildable. ......
    Yeah, some JD cyls (like the 955's referred to above) have welded-on glands, and have
    to be cut open to get at the innards. They can be rebuilt if you are willing to do that,
    and weld them back closed. I assume the piston is held on with a nut.
Similar Threads
  1. John deere 855 power steering cylinder
    By denny0658 in forum John Deere Owning/Operating
    Last Post: 06-16-2012, 07:41 AM
  2. John Deere 455 steering cylinder leaking
    By andrew1346 in forum John Deere Lawn & Garden
    Last Post: 09-18-2011, 10:57 PM
  3. John Deere 455 steering cylinder leaking
    By andrew1346 in forum Parts/Repairs
    Last Post: 09-16-2011, 09:07 AM
  4. 4110 has leak in power steering cylinder
    By mikeinvt in forum Mahindra Owning/Operating
    Last Post: 05-12-2006, 10:04 PM
  5. John Deere 4400 steering cylinder failure $$$$$$$$
    By Cactus in forum Parts/Repairs
    Last Post: 08-20-2005, 08:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
