kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,910
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
How do I got about replacing the seal on the input shaft on the gearbox? Will I have to drain the rest of the fluid, then remove the 4 bolts that hold the front plate on, then pull the shaft out? It looks like once you do that, the shaft should slide out of the plate from the rear, which would give me access to the seal, right?? Does the new seal have to be pressed in? Sorry for the lousy pic, I took it with the cell camera today cause I forgot my good camera.
Thanks.
Thanks.
