Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Lakeville, Ohio
    MF 135
    Default 1956 Ferguson To 35
    I have a 1956 Ferguson To 35, and I'm having an electrical problem. I have been having problems with the points fouling up after it ran for a while, so I went ahead and gave it a tune up, (new plugs, points, condenser, cap, and rotor). That helped a little, but the same thing started happening again. To me it seems the spark is awful week and sporadic. I had it out the other day to do some tilling and it started OK, but ran a little rough, and eventually died in about 15 minutes. I started checking things out but I couldn't get it started again and eventually ran down the battery. I've been through the carburetor and fuel system, everything's OK in the at area. I checked the spark, and again it was weak to me and at times not at all. Is it a coil issue, ignition module problem, or what? Any help would be appreciated. Thanks - Gary
  2. #2
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    Default Re: 1956 Ferguson To 35
    I'd finish the tune up with a new coil and wires. Are your sure the gap on your points isn't too wide.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  3. #3
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Lakeville, Ohio
    MF 135
    Gaps are all to specs, and plug wires are fairly new. I checked the spark at the distributor points, and that's where it appears weak and not at all.
  4. #4
    Elite Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    New Holland TD95D, Ford 4610 & Kubota M4500
    Quote Originally Posted by Gary Mickle View Post
    When you say "I have been having problems with the points fouling up after it ran for a while....", do you mean the points are burned? if so, they are set too close, you have a 6V coil (1.6 ohms primary resistance) in a 12v electrical system without a ballast resistor, or your voltage reguator is keeping the system voltage too high. All of these will result in a a pimary curent greater than about 4 amps max and will cause the points to burn. A faulty condensor can also cause some arcing at the points and cause them to burn.
    Many times a conversion from a 6V system to a 12v system causes this problem because the original 6v coil is used without a current limiting resistor or the coil is not replaced with a 12v coil (3.2 ohms primary resistance) Like NAPA IC14-SB.
  5. #5
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Lakeville, Ohio
    MF 135
    Thanks for the info. I haven't had this tractor a long time and it is converted to a 12 volt system. I need to do some more investigating and check the coil. When the points fouled before there was a carbon buildup on them. I don't have that problem now since the tune up, but just the weak spark or no spark. I know it needs to be timed better, so I'll do some more investigating. Thanks again for the input. - Gary
  6. #6
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    "When the points fouled before there was a carbon buildup on them."Carbon build up on the breaker points??? Are you getting oil in the distributor? if so, make sure the crankcase vent tube is not clogged.
  7. #7
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Lakeville, Ohio
    MF 135
    There's no oil in the distributor. I should of stated that the points would just foul up with a little bit of carbon between them, (which I assume is carbon), and I'd just take a piece of fine sandpaper folded and run between them a few times to clear them. Why they were fouling in the first place, I don't know, other than caused by a weak spark?. As I said, I haven't had this tractor a long time and ran it for any period of time to find all the bugs it may have that I wasn't told about when I bought it. It doesn't use oil, fluids are all good and clean, no leaks that I can find so far, and the ones that had it before me had supposedly had gone through it and then gave it a new paint job. I don't know if that's when it was converted to 12 volt system and nobody has used it enough, for the problem I've been having, to show up or what. I'm going to go ahead a put a new coil on it and see if that works, and go from there. I appreciate your input. Thanks again - Gary
  8. #8
    Join Date
    Feb 2008
    Posts
    2,608
    Western Montana
    Have you checked the other things I listed in my first post? You want to find the root cause of the problem before you start thowing parts at it.
    You might try replacing the condensor also. They're cheap and the modern ones often fail and there is no easy way to test them. Try that first and then replace the coil.
    Make sure that there is not an excess of grease on the cam. It can get thrown off on to the points and foul them. if you use breaker point grease it should not be a problem but you only need a little dab.
  9. #9
    New Member
    Join Date
    Apr 2012
    Posts
    8
    Lakeville, Ohio
    MF 135
    I'll do that. Thanks Again. - Gary
  10. #10
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    so far my guess is that you are running a 6v coil on 12v and burning the points. the sanding has ruined them by removign the hard coating meaning they will pit faster now.
    get the correct coil.. napa ic14sb...
Similar Threads
  1. 1956 ford
    By canadianfarmboy in forum Ford Vintage Tractors
    Last Post: 05-21-2012, 09:01 AM
  2. 1956 David Bradley
    By skent in forum Photos
    Last Post: 04-27-2011, 08:23 PM
  3. 1956 Farmall cub
    By frank_f15 in forum General Vintage Tractors
    Last Post: 01-29-2008, 01:46 PM
  4. 1956 John Deere 50.
    By DmaxEter in forum John Deere Vintage Tractors
    Last Post: 06-17-2005, 03:24 PM
  5. 1956 Willys Pickup
    By rockyridgefarm in forum Related Topics
    Last Post: 04-18-2005, 10:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
