Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Sep 2011
    Posts
    13
    North Carolina
    Kubota M6950DT and Kubota L3240
    Default Tire Repair - Inside patch or Slime?
    I have a pinhole leak (very small puncture) in the tread of my tractor front tire. I'm undecided whether to get the tire dismounted and patched from the inside ($$$) or just buy a can of Slime and seal the small hole. Anyone have any experience with the Slime approach? I don't want to put the goo in the tire and then regret it later.
    SalisburySenior
    Kubota M6950DT (1983)
    Kubota L3240 (2007)
    Loader, backhoe, box blade, scrape blade, rotary cutter, wood chipper, posthole digger, pulverizer
  2. #2
    Join Date
    Apr 2009
    Posts
    111
    Default Re: Tire Repair - Inside patch or Slime?
    I bought a atv not to long ago and the tires had numerous holes in them, so i put about 4 oz in each tire.
    Seemed to work pretty good and when i bought new tires and had to take them off it wasnt that bad. Just wiped the rim with some paper towels. Of course i was putting new tires on and didnt have to worry about getting it off of the inside of the tire. Any reason why you cant just put a plug in it?
  3. #3
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    I carry slime in my pickup, only had to use it once and it worked well. If I had my choice with a tractor it would be a tube. I also slimed the tires on my ATV as insurance against getting stuck a couple of miles from home with a flat. The trip to my hunting spot was very rocky in places and over the course of 5 years the slime never let me down. You will have a major mess if you have to reuse a slimed tire. Do you know what caused the leak?
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  4. #4
    Gold Member uglyboywith11fingers's Avatar
    Join Date
    Sep 2011
    Posts
    357
    Georgetown, Ontario
    2007 BX24TLB, 1998 TG1860G
    I had a slight leak in the sidewall of a front tire (R4) on my BX24. I slimed both at the same time, early this past spring, and have had no drop in pressure through a lot of FEL work.
    Many people advise against slime, but for my sidewall leak, it was either that or tubes.
    I would use slime again.
    Pete
  5. #5
    New Member
    Join Date
    Jul 2012
    Posts
    23
    Jacksboro, Tx
    Yanmar YM2000D
    I have slime in my tractor, atv, golf cart so basically anything that has rubber tires since everything in TX has a thorn or rock associated with it. I've had good luck with the slime and wouldn't run without it.
  6. #6
    Gold Member mvwicker's Avatar
    Join Date
    Sep 2009
    Posts
    325
    St Louis, MO
    2007 New Holland TC34DA
    I also had front tire leak. Took the wheel to one place that charged $25 to put a patch on the inside. The guy who did it said he uses Slime on his ATV tires as a preventative measure. He also said that a locust thorn was the likely culprit, and I can believe it. Those things are nasty.
    Tire plugs work fine when the car picks up a nail or screw, but who wants to ream a pinhole out to 1/4" ?
  7. #7
    New Member
    Join Date
    Sep 2011
    Posts
    13
    North Carolina
    Thanks to all who responded. In answer to a question ---- I'm not using a plug because the puncture is like a pinhole and is through the thickest part of the agressive tread.
    SalisburySenior
    Kubota L3240 (2007)
  8. #8
    Gold Member
    Join Date
    Nov 2011
    Posts
    271
    Canton, TX
    JD 301A and yanmar YM2500
    Default
    Only 1 real issue with slime is when you get a hole that needs a patch you can't patch it. And that goes for tires or tubes.
  9. #9
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,431
    Yanceyville, North Carolina
    Kubota L4400
    Quote Originally Posted by mvwicker View Post
    I can relate to the issue rgarding black locust thorns. Had a flat on our golf cart last week due to one. The tube cost me $11.00.
    The PUPIL who does not surpass his Master, fails his Master.
  10. #10
    Veteran Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    1,198
    Indianapolis
    Kubota L3940 Ford 8N Ford 6000
    I was driving my brand new tractor home from the dealership, owned it less than 15 minutes, and had this 1/4" button head screw go thru my rear tire. I nearly cried. You can still see the manufacturers sticker on the tire! I performed an external plug job, 3 years later, no issues. Philip.
    Attached Thumbnails Attached Thumbnails Tire Repair - Inside patch or Slime?-screwtire01.jpg
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/quick attach
    HD 72" round back bucket
    turf tires
    Kubota GR2120 2013
    Ford 8N 1950
    Ford 6000 diesel 1961
    JD L110 2003
    Woods RD7200 finish mower, Land Pride RCR1272 rotary cutter, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, sub-soiler, post hole auger, 3 point pallet forks, 30" rear scoop, 7' Land Pride RB1584 rear blade, 3 point boom pole
Similar Threads
  1. car tubeless tire patch won't stick
    By bjr in forum Tires
    Last Post: 06-26-2010, 12:49 AM
  2. Replies: 4
    Last Post: 08-31-2007, 12:24 PM
  3. Tires Ag tire repair/patch
    By acs55812 in forum John Deere Owning/Operating
    Last Post: 03-18-2006, 10:48 PM
  4. first flat tire, anyone use "tire slime"?
    By aardvark in forum Tires
    Last Post: 10-16-2004, 07:57 PM
  5. Tires Does SLIME eat away at the inside of the tires????
    By Von in forum Owning/Operating
    Last Post: 11-08-2003, 07:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
