Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Aug 2012
    Posts
    3
    Pomfret, Connecticut
    JD X300
    Default K46 Rebuild - Still having issues
    Good morning. It's my honor to be the newest member to tractorbynet.com. While mowing with my 2007 JD X300 (actually when I was repositioning the tractor) last weekend I completely lost forward, reverse and parking brake. Not really confident that I had the same problem as others who went with the K46 rebuild, I gave it a shot anyway, following the instructions found on this site. I figured, what the heck, it seems to have working for almost everyone else who tried the rebuild, and it probably won't be a complete waste of money either way.
    What was unique about my problems, compared to all others who attempted the rebuild, was that I lost all transaxle responsiveness immediately. I didn't notice a loss of power...the unit was whiny and underpowered to begin with. My biggest reason to doubt that a rebuild would fix the issue is because of the immediate loss of F, R and brake and I could push the tractor with the brake engaged, as opposed to the gradual loss of power reported by all others.
    I have a bad habit of replacing unneeded parts, to substitute for my lack of mechanical troubleshooting skills. I am into this for $180 already. Seeing that I have no brake, I have to assume the failure is within the gears, somewhere after the disk that engages the brake. I didn't see any excessive ware on the gears but you can hear the gears within the transaxle grinding (operating the unit on jacks, the wheels will turn until you apply a small amount of pressure. They are easily stopped and that's when you can hear the grinding. I am assuming I've got issues around #10, 12 and 13 on attached image. Looking for some feedback from the experts on this before I go replacing more unnecessary parts. K46 Rebuild - Still having issues-oe-055.jpg
    Thanks so much for your help.
  2. #2
    New Member
    Join Date
    Aug 2012
    Posts
    16
    Boise, ID
    2005 JD L118
    Default Re: K46 Rebuild - Still having issues
    Charles, it does sound like the gears on the differential side have failed. I imagine if you examine the cogs & teeth closely, you find gears where teeth are sheared off. Replacement parts can be purchased directly from Tuff Torq online cheaper than through John deere. Good luck.
Similar Threads
  1. K46 rebuild
    By Penland65 in forum Parts/Repairs
    Last Post: 03-12-2012, 06:52 PM
  2. Massey 165 Gas..rebuild issues :O
    By MBMassey in forum Massey Ferguson Owning/Operating
    Last Post: 05-10-2011, 02:27 AM
  3. K46 Oil level
    By 2manytoyz in forum John Deere Lawn & Garden
    Last Post: 05-04-2011, 07:10 AM
  4. JD K46 Problem is finally here HELP
    By desert1957 in forum Parts/Repairs
    Last Post: 04-25-2011, 08:49 AM
  5. Is this too much grade for a K46 transmission?
    By BMWBig6 in forum General Lawn & Garden
    Last Post: 04-30-2008, 11:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
