Results 41 to 50 of 60
10-06-2012, 12:21 AM #41
Re: 1952 Ford 8N won't start
Don
MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
10-06-2012, 07:38 AM #42New Member
- Join Date
- Sep 2012
- Posts
- 5
- Location
- Indiana
- Tractor
- Ferguson T020, Kubota B3200
If the switch is closed/on you will read no voltage across the switch. The meter is reading the "difference" in voltage so with the switch closed you are reading the same voltage ie 0 volts. When you open/off the switch you should read 6 volts because there will be 6 volts difference between the two points. I will try to attach a very crude drawing of what's happening...
10-06-2012, 09:02 AM #43Elite Member
- Join Date
- Feb 2011
- Posts
- 3,853
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
That's a pretty good accusation to make for someone you don't even know. I think I am more than capable of getting a old tractor running. If the guy would have listened to the advice I gave in post 3 or 7 his tractor would be running. That is good advice for any old tractor/ car with no spark.
Originally Posted by Don87
10-07-2012, 01:15 AM #44
No offense was intended from me, but the first thing you'll notice is that post number 3.........made by you was totally innacurate.............OP has negative ground.
Post number 7, made by you, was totally overuled by Soundguy, where................I believe he show 5 instances(I would need to count), where your diagnosis was innaccurate, and required more troubleshooting.
I wasn't trying to be a smarta**..............I just know when to turn the reigns over to the experts, that have been working on these since before you and I were born.Don
10-07-2012, 10:13 AM #45Elite Member
- Join Date
- Feb 2011
- Posts
- 3,853
- Location
- Tractor
What's with these guys and never posting back? Did the OP get his 8N running?
If you know anything about a 8n, they were all 6 volt positive ground. Most but not all 6 volts are positive ground. I really don't see were Soundguy said to do more troubleshooting than what I did in post 7.
10-07-2012, 01:16 PM #46Elite Member
- Join Date
- Feb 2011
- Posts
- 3,853
- Location
- Tractor
They are positive ground
scroll down to the bottom of the first table Old Ford Tractor Specifications and Data
Click on the 4th page, (it is number 12 in the manual) 1948 Ford 8n: Ford 8n Specs
Maybe I do know a little bit about what I'm talking about.
10-07-2012, 04:16 PM #47New Member
- Join Date
- Sep 2012
- Posts
- 9
- Location
- york, pa
- Tractor
- 1947 Ford 8N 6v positive ground system front mount distributor sn 10101 all OEM
10-07-2012, 08:05 PM #48New Member
- Join Date
- Sep 2012
- Posts
- 5
- Location
- Indiana
- Tractor
First, make sure you have your voltmeter set to DC volts and not AC volts, been there done that!
I've found several different wiring diagrams of the 8N. One shows three wires on the key switch. The one from the battery you should see 6v to ground on that wire. If not then you have a broken wire, bad connection, bad wire end etc or a dead battery. This wiring diagram is the simplest one I found, although it appears some of it may be left out so I didn't include a link to it.
The other diagram shows shows a wire from the terminal block to the key switch then a wire from the key switch to the coil. From the terminal side of the key switch you should see your 6v to ground. If not then again its a bad wire, bad connection etc. You need to follow the wiring backwards until you find 6v to ground then work your way back to the switch replacing the wire, the ends or whatever it may need.
Heres a pretty good wiring diagram.
Harper Farms - Morgan County Georgia
Heres another of basically the same thing, although the first one appears to be a little easier to read
8N FRONT MOUNT WIRING INFO-ORIGINAL 6-VOLTLast edited by moog; 10-07-2012 at 08:23 PM.
10-07-2012, 09:18 PM #49New Member
- Join Date
- Sep 2012
- Posts
- 9
- Location
- york, pa
- Tractor
10-07-2012, 09:46 PM #50New Member
- Join Date
- Sep 2012
- Posts
- 5
- Location
- Indiana
- Tractor
After looking at the diagram again I used a bad description, told you wrong or just flat out lied to ya, however you choose to look at it, although it was accidental. Both wires do come from the terminal block. The wire from the ammeter to the terminal block should be your 6v to ground. The wire then goes through your switch back to the terminal block then over to the coil. Sorry for the confusion.
Similar Threads
1952 8N Ford
By Laurieshood in forum Ford Vintage TractorsReplies: 7Last Post: 06-05-2012, 04:18 PM -
1952 Ford 8n...worth buying?
By bige1973 in forum Owning/OperatingReplies: 30Last Post: 06-14-2011, 06:43 AM -
1952 ford 8n
By smitty1127 in forum Private Party AdsReplies: 11Last Post: 02-18-2011, 10:55 PM -
Oil & Fuel 1952 Ford 8N fuel problem?
By denden1960 in forum New Holland Owning/OperatingReplies: 5Last Post: 05-04-2010, 01:25 PM -
1952 ford 8N restoration
By Soundguy in forum Ford Vintage TractorsReplies: 12Last Post: 08-23-2002, 05:08 PM
