Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2011
    Posts
    62
    Northern Pa
    farmall m, Allis Chalmers WD x2, Husky 390XP, Husky 455 Rancher
    Default 2040 John Deere brake problem
    Have a 2040 John Deere that has a brake issue. When we were baling hay last summer we lost the one side brake, this year we were baling hay and lost the other side also. Tore the brake valve off the tractor and installed a rebuild kit, did not see anything real wrong with the valve componets but found that there was a silver substance in the valve that looked like silver anti-seize, cleaned out the valve, drained oil, replaced filters and rebuilt the valve. Installed the valve that was rebuilt and tried to bleed the brakes, can not get the brakes to bleed, if the ports from the valve are plugged there is pressure at the pedal, not sure where to go with this.
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,808
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: 2040 John Deere brake problem
    By not getting the brakes to bleed, do you mean you can not git rid of air? Or you are not getting any fluid out when you try to bleed? Sounds like something is plugged. Brake line, passage, bleeder.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    Join Date
    Nov 2011
    Posts
    62
    Northern Pa
    getting fluid out when trying to bleed, plugged the lines and the pedals get firm, when the tractor was reved up the pedal had a little firmness but when the tractor was idled down the pedal has nothing.
Similar Threads
  1. 1981 John Deere 2040 with over heating problem
    By Oletrapper in forum Hydraulics
    Last Post: 02-06-2016, 05:20 PM
  2. John Deere 4420 combine brake problem
    By VA Rebel in forum Ag Tractors & Machinery
    Last Post: 03-01-2012, 09:36 PM
  3. John Deere 2040 Hydraulic Problem
    By baustin in forum John Deere Owning/Operating
    Last Post: 10-04-2011, 07:39 AM
  4. John Deere 2750 Brake problem
    By Butters in forum Parts/Repairs
    Last Post: 11-12-2009, 10:28 AM
  5. 1981 John Deere 2040 with over heating problem
    By Oletrapper in forum Owning/Operating
    Last Post: 08-05-2008, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
