Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    4
    JAckson, Tn
    John Deere 3410
    Default John Deere 4310 Hood Replacement
    Has anyone ever replaced the hood on a JD 4310. When I bought mine (used from a friend) the hood was badly cracked. While bush hogging the hood just fell apart. Ordered a new hood, fuel door and hood/tank pads and seals. Need to know where to put the new pads (part # LVU10461 & LVU10458). Does anyone have a diagram showing where to place these pads. I know they go somewhere around the fuel door area, but where exactly! Also any tricks on installing the springs that hold the fuel door in place.
    Thanks in advance.
  2. #2
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,641
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Default Re: John Deere 4310 Hood Replacement
    Do you mean the foam pads in this picture? There are outlines on the inside
    of the hood showing where they go. For my second new hood, I did not
    install the pads as they do not seem to add anything.
    If you do a search you can find numerous posts on hood and door installs,
    including my recent thread:
    http://www.tractorbynet.com/forums/p...nels-fuel.html
    Attached Thumbnails Attached Thumbnails John Deere 4310 Hood Replacement-fuel_door2-jpg
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    4
    JAckson, Tn
    John Deere 3410
    Thanks. I did not notice the outlines on the inside of the hood. I will try it tonight when I get home.
  4. #4
    Gold Member
    Join Date
    Mar 2011
    Posts
    278
    Pontotoc Ms
    jd 4610
    When I replaced my hood on the 4610 I left the fuell door & stickers off figured I have to replace the hood again any way
    Bought my tractor new fuel door broke of within a year. hood broke within 2.
    My tractor is not in any way abused, just used
    JD plastic is junk purely simple junk
  5. #5
    Join Date
    Feb 2004
    Posts
    5,641
    NorCal
    Quote Originally Posted by plowindeeper View Post
    No question the fuel door and the hood's side stickers are optional items for
    a finished look. The plastic is very vulnerable to impact, as you found out.
    Maybe you should try some hood armor?
    Sadly, the prices of the stickers have gone from $16 ea to $24 each after only
    two years. I think that JD sells a lot of new hoods.
  6. #6
    Gold Member
    Join Date
    Mar 2011
    Posts
    278
    Pontotoc Ms
    jd 4610
    I don't think hood armor would help. The UV ray"s and heat do the damage. It's keep in the shed but I wish they had metal hoods. I can fix and paint metal and fiberglass. Soybeans mashed in the shape of a hood are a different story. For about $2100 It all can be replaced though.
  7. #7
    New Member
    Join Date
    May 2012
    Posts
    4
    JAckson, Tn
    John Deere 3410
    Thanks for the advice. I went ahead and put a new fuel door and stickers on the hood just to give it a finished look. But I do have a question. You suggested that I use some "hood armor". I have never hear of "hood armor". What is it and where can it be purchased?
  8. #8
    Gold Member
    Join Date
    Mar 2011
    Posts
    278
    Pontotoc Ms
    jd 4610
    John Deere dealer sells it. It's a short piece of metal to cover half the hood, metal mesh guards for head lights, and covers for the hyd. Hoses on the loader. It's a kit to protect you hood from falling debris when useing loader
  9. #9
    Join Date
    Feb 2004
    Posts
    5,641
    NorCal
    Quote Originally Posted by wmgareyd View Post
    Here's a photo from one of my rebuild threads. It is part of the "rental service kit"
    you can get from Deere.
    The hood armor in the kit is welded to a larger grille guard and weighs maybe 100#.
    The part over the hood is 1/8" steel plate. The whole thing pivots out of the way
    so you can open your hood.
    I made my own armor for my Kioti.
    Attached Thumbnails Attached Thumbnails John Deere 4310 Hood Replacement-before_2-jpg   John Deere 4310 Hood Replacement-dscn0220-jpg
Similar Threads
  1. 325 john deere hood
    By davetd in forum John Deere Owning/Operating
    Last Post: 08-01-2010, 10:31 PM
  2. 325 john deere hood
    By davetd in forum New Member Introductions
  3. John Deere 5300 Hood
    By KRH in forum Wanted Ads
    Last Post: 11-27-2009, 06:56 PM
  4. Hood for John Deere 345
    By tinmanok in forum John Deere Lawn & Garden
    Last Post: 01-09-2009, 06:47 PM
  5. Replacement hood for a John Deere 4300 Tractor
    By Dwasdin in forum John Deere Owning/Operating
    Last Post: 10-10-2005, 10:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
