Results 1 to 6 of 6
  1. #1
    Join Date
    Jun 2003
    Posts
    2
    Default 3-point problem
    While rototilling some rough ground the three point went out and was unable to lift the tiller. I have a Satoh Stallion (1980) and the loader works fine. Any ideas on how to fix this? Thanks.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Re: 3-point problem
    Sounds like the internal relief let go or is stuck open. [img]/forums/images/graemlins/confused.gif[/img]
    If you remove all attachments will it try and move?
  4. #3
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Or an O ring on the piston tore. If the loader is working fine and it is driven by the same pump then I would not think relief valve.
    However is the lift has its own pump then all bets are off.
  5. #4
    Gold Member
    Join Date
    Oct 2002
    Posts
    317
    Middle Tennessee
    John Deere 4410
    Sounds like a piece of contamination or metal fragment may have gotten into the lift arm valve. If you have a filter for your 3 pt. hitch like mine does; you might try cleaning it out and try it again. Otherwise you may have to do some surgery ton the pt. lift. [img]/forums/images/graemlins/confused.gif[/img]
  6. #5
    Gold Member gator's Avatar
    Join Date
    Apr 2001
    Posts
    388
    NC
    JD 750 (first was '62 AC D-12 w/ factory 3pt.)
    If the TPH acts dead, I would start at the TPH control lever and work my way to the TPH housing, moving the lever and making sure all the attached linkages are moving to. One might of come loose. Also would check for a shut off/bypass handle below the seat, may have vibrated to hold/bypass position if it has one.
    If its attempting to lift but doesn't, I would do like the others recommended.
  7. #6
    Join Date
    Jun 2001
    Posts
    711
    Some of those machines do have a seperate pump for the 3ph as well as a seperate clutch/engaging lever.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
