I just went today and bought all new filters but the Cat dealer had to order one part. They said it might be the part they are ordering that is causing the problem so I have to wait and see about that. The air restriction indicator hasn't appeared to work since I have owned it (about 6 years). It has no warning lights at all. I cleaned everything I know to clean, pressure washed the engine compartment, radiator, scooped out all the gunk I could get out from under the engine, etc. I changed the final fuel filter and checked the breather, breather hose, ordered the part that my book says is a primary fuel element but the dealer says it isn't called that. I will pick up part tomorrow and try it again.
I appreciate any advice. I am learning as I go. Thanks
