Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    1
    webster, Ma
    Case 580CK
    Default case 580ck backhoe boom cylinder seal replacement
    What kind of tools are needed for replacing a leaking seal on Case 580CK Backhoe Boom Cylinder?
    Information will alo be appreciated on how to remove the leaking Cylinder Seal.
    Thanks,
    Bill
  2. #2
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,175
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    Default Re: case 580ck backhoe boom cylinder seal replacement
    Place the boom in a safe position, (most of the way down, but not all the way, and where it cannot possibly fall)
    Bleed off the hydraulic pressure. (wiggle the controls with the engine off)
    Remove hydraulic hoses from the cylinder.
    Remove upper and lower pivot pins.
    Remove gland from upper end of cylinder. (it unscrews, right-hand threads) You will need a spanner wrench, like this: spanner wrench
    Remove gland and piston rod assembly from cylinder housing.
    Remove large nut from end of piston rod. (this may require a 1" impact air wrench)
    Replace inner and outer seals and rings on piston, as well as the seal and rings in the gland.
    Reassemble in reverse order.
    Note: Lubricate all seal/ring surfaces before reassembly. Place tape over threads to keep from damaging new seals/rings. Remember to remove tape before screwing parts back together.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  3. #3
    Join Date
    Aug 2008
    Posts
    2,175
    After I posted, I looked back up and saw that was your first post.
    '81 Ford 2600
  4. #4
    Gold Member
    Join Date
    May 2009
    Posts
    256
    Central Illinois
    several kinds and sizes
    Also helps to have strong buddy to help hold/lift the parts, AND a couple cases of Bud Light will ease the mashed fingers!!!LOL!!--- just be careful around them suckers,-- they will gittcha if they git a chance!!!---How do I know?--- been there--- done it! thanks; sonny 580
  5. #5
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,921
    Northern Vermont
    Kubota, Case, Deere
    I like to leave the pins in while I loosen the gland nut on the end of the cylinder. I've never had luck with spanner wrenches, a 3 foot or 4 foot pipe wrench is always my fall back that works. On my 580k there's a small screw that holds the gland nut in place. The nut tightens up until two half circles meet and then the screw goes into the hole. When loosening and tightening the bolt at the end of the rod you can put it back on the tractor with the pin unless you have access to a large vise to hold the rod. Be careful not to damage the chrome finish.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
Similar Threads
  1. Old Case 580CK for farm backhoe
    By HuskerInVA in forum Construction Equipment
    Last Post: 06-01-2016, 11:27 AM
  2. Case 580 Hydraulic Cylinder seal replacement
    By TommyTee in forum Construction Equipment
    Last Post: 09-09-2014, 09:25 PM
  3. Replies: 5
    Last Post: 09-17-2012, 08:04 PM
  4. Boom cylinder seal repair 580 B
    By Robert Cosgrove in forum Hydraulics
    Last Post: 11-11-2011, 10:31 PM
  5. Cylinder seal replacement
    By Iellis in forum Parts/Repairs
    Last Post: 09-24-2010, 07:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
