Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    3
    Henderson, TN
    Satoh S-650G
    Default Satoh S-650G water pump
    Bought used 16 years ago. Had 908 hours when cable went out couple years ago. Use it about 3-5 hours year. Bush-hogged yesterday and noticed water leak. Pump is shot, need to replace. Can anyone help me determine what year and what engine I have from the information below?
    Stamped on transmission housing by clutch:
    Satoh S-650G-600037
    Stamped on engine block left side rear:
    S275525
    Label on frame right side mid engine:
    SATOH TRACTOR S-650G
    Disp: 60.23 ci 25 hp/2800 rpm
    Satoh Agricultural Machine Mfg. Co. Ltd.
    Want to make absolutely sure I get right part first time.
    Thanks for any help.
  2. #2
    Join Date
    Mar 2009
    Posts
    57
    New Brunswick, Canada
    Default Re: Satoh S-650G water pump
    Those tractors had a Mazda engine. I'm not sure whether you can still find parts, however an IH284
    had the same engine...maybe Case-IH would be able to supply a water pump.
    David
  3. #3
    New Member
    Join Date
    Sep 2012
    Posts
    3
    Henderson, TN
    Satoh S-650G
    Compact Tractor Parts shows Mitsubishi water pump in the IH284 at Mitsubishi Tractor Parts: Cooling System Parts || Weaver's Compact Tractor Parts & Compact Tractor Salvage .
    Would a Mazda engine have a Mitsubishi water pump?
  4. #4
    New Member
    Join Date
    Sep 2012
    Posts
    3
    Henderson, TN
    Satoh S-650G
    To answer my own question and for general information:
    It appears that all Satoh S-650G 'Bison' tractors have the same Mazda engines from the early '70s' through '80s' to about '93'. There are 3 sources for parts. Valley Power Products, satohparts.com , Weaver's Compact Tractor, compactractorparts.com and Wengers of Myerstown, wengers.com . Prices from $109.00 to $150.00. As far as rebuilding the pump myself goes I think I'll pass. One source quoted $90.00 just for the seal. May be able to get a thermostat from Auto Zone for just a few bucks. I will follow up this post with details after the fact.
  5. #5
    Join Date
    Sep 2002
    Posts
    1,612
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    If you have a good parts store let them send it to their rebuilder if you have time. It might take a couple weeks. I did this probably 15 years ago on my Satoh for about 40 bucks compared to 150. Mine is the S-470 Buck.
  6. #6
    New Member
    Join Date
    Mar 2006
    Posts
    17
Similar Threads
  1. Satoh Buck S470-D Water Pump
    By LPSterner in forum Mitsubishi/Satoh
    Last Post: 02-05-2011, 12:17 AM
  2. Satoh beaver...need water pump
    By oldyeller in forum Mitsubishi/Satoh
    Last Post: 02-14-2008, 01:06 AM
  3. Water Pump Leak on '81 Satoh S-630 Bull
    By Lane in forum Mitsubishi/Satoh
    Last Post: 08-13-2006, 09:06 AM
  4. Satoh 650 water pump
    By bluechip in forum Mitsubishi/Satoh
    Last Post: 09-13-2003, 12:29 AM
  5. Satoh 650G Water Pump
    By Anonymous Poster in forum Mitsubishi/Satoh
    Last Post: 03-24-2003, 11:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
