Results 1 to 2 of 2
09-25-2012, 01:40 PM #1New Member
- Join Date
- Sep 2012
- Posts
- 1
- Location
- Creighton, Mo
- Tractor
- 851 Powermaster
851 Powermaster 3 point
I purchased a Powermaster 851. Runs great. I hooked a blade up to it to work on my drive way. It comes up about a foot and begins to pulsate. Will not go up any further.
Fluid level is good. Anyone have any thoughts or suggestions?
Thank you,
Brad
09-26-2012, 08:36 AM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 851 Powermaster 3 point
without the blade will it go up higher?
do you have the draft control set straight over ( up ) for position control?
with the blade on and it pulsing, and the hydro fill cap off.. look in with a strong light and see if you have fluid pouring out the mouth of the cyl.
the pump only makes 4gpm max.. if the load is heavy and the leak bad... well..
lift cover gasket and oring kit costs a whopping 15$
might also have a worn cam follower pin and / or cam surface. pin is repalceable, cam can be built up with weld and reground... it usually wears in profile and leaves a witness mark to weld back up.
pulsing is leakdown and circuit regen.
if it lifts higher with no load.. it's a bad leak.
if it does not lift higher, then the lift is out of adjustment.. most likely due to a very worn cam pin / cam...
Similar Threads
Ford 851 RESTORE
By Ford851 in forum Ford Vintage TractorsReplies: 9Last Post: 06-19-2012, 08:52 AM -
851 Powermaster vs tiller
By 851 roger in forum Ford Vintage TractorsReplies: 7Last Post: 01-27-2011, 06:07 PM -
FORD 851 Powermaster
By leftybob in forum Ford Vintage TractorsReplies: 23Last Post: 05-21-2010, 04:30 PM -
ford 851 issues
By bcnla in forum Parts/RepairsReplies: 7Last Post: 08-17-2009, 06:26 PM -
ford 851-D
By tpl77 in forum Owning/OperatingReplies: 3Last Post: 08-02-2005, 03:15 PM
