Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2011
    Posts
    195
    NW Ohio and SE Michigan
    Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
    Default Sears Suburban 10 garden tractor with vintage Tecumseh Engine
    Model 143-579032 serial 6287 ? on the id plate 12135
    I found this neat small tractor at auction and I want to use it to cultivate between planted rows with a self propelled Sears Rototiller mounted on the rear. Who knows how long it sat unused so I started with clean fuel and oiled the cylinder and it turned easily. Then I tested for spark and of course none. So I took off the engine cover and there was considerable rust on the magneto/flywheel which cleaned off nicely. The condenser was rusty but cleaned nicely and I tried to replace it (internet as well as old Tecumseh small engine shops) but no success. Well I decided to try to start it with what I had and as I was moving the spark wire coming out of the ignition coil it literally fell out. So I then went back to internet (e-bay etc.) as well as small engine repair shops but only response was "no longer available".
    Questions:
    1. Any one know where I can find coil 32014 condenser 32015...(these are according to a Sears Vintage Restorers website)?
    2. Has anyone experience with reinserting the SP wire into the housing of the ignition coil (after appropriate cleaning both wire tip as well as internal coil) sealing the connection?
    3. If either of the above two options do not succeed, can another coil be substitutedif it has the same fit/contour to the flywheel?
    Thank YouSears Suburban 10 garden tractor with vintage Tecumseh Engine-img_0020-jpgSears Suburban 10 garden tractor with vintage Tecumseh Engine-img_0026-jpgSears Suburban 10 garden tractor with vintage Tecumseh Engine-img_0019-jpg
  2. #2
    Platinum Member Steave's Avatar
    Join Date
    Mar 2012
    Posts
    845
    Taylorsville, GA
    3000 Ford 66' 260A International Backhoe, Belarus 250AS
    Default Re: Sears Suburban 10 garden tractor with vintage Tecumseh Engine
    Not real sure but its worth a try. Put" Part Number: 35135B " in google it brings up tecumseh coils from different sellers. Hope this helps.
    I've got a cutting torch and a welder sooo YEAH it'll fit!!
  3. #3
    Join Date
    Jun 2011
    Posts
    71
    Enfield, CT
    Kubota B7100
    You could remove the stock coil and wire in an automotive 12 volt coil.
  4. #4
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,151
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Coils are out there if you Google as mentioned. Not cheap, but they are out there... Saw one for like $85. The condenser is still available through NAPA. My local price here is something like $8.14. Some on Epay for $8.99 and up.
    Pretty cool you're bring it back to life..!! I have more than several David Bradley 2 wheeler's sold through Sears, I use in the garden. Great for marking rows, and cultivating.. Sure beats a hoe..!!
  5. #5
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    991
    Ct
    Yanmar 2020D
    The 32014 is long gone but can be found on ebay...they get top dollar.
    Try these two links for assistance. Engines&Magnets
    overnight solutions which has a fix: Home
    and a video : Overnight Solutions HET ignition Sears Suburban - YouTube
    These engines and trzctors are awesome and really were built well. the ignition module is the weakest link because it is NLA. good luck
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
    Yanmar Tractor Database - Click Link, then click file and download the excel file.: https://drive.google.com/file/d/0BxR...it?usp=sharing
Similar Threads
  1. Old Sears Suburban SS12
    By jwstewar in forum Craftsman / Sears
    Last Post: 06-20-2013, 09:59 AM
  2. sears suburban ss15
    By georgia plow boy in forum Craftsman / Sears
    Last Post: 02-15-2013, 02:27 PM
  3. Sears Suburban tractor and implements
    By Scotty Dive in forum Craftsman / Sears
    Last Post: 07-08-2012, 08:20 PM
  4. Pulley removal-Bolens-Tecumseh GT1443 garden tractor
    By flusher in forum Parts/Repairs
    Last Post: 01-22-2012, 09:29 PM
  5. Sears "Suburban" Garden Tractor [?}
    By gdtractor in forum Craftsman / Sears
    Last Post: 04-10-2006, 12:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
